Will this kit fit my 85L?
- the boy from tas
please see attached picture and tell me if its the right kit..
thanks guys
							thanks guys
				- lift.jpg (116.75 KiB) Viewed 2097 times
- brumbybear
- the boy from tas
- the boy from tas
yeah thats where i got it so guess its yours! small worldVenom wrote:Looks like the 3" BYB kit i sold on ebay. If it is then it should fit. The lift kit was made for an L series with power steering rack. If you have a manual steering rack then the steering extension won't be the right size, but everything else should be ok.
well i was looking around and and can see where most things are going to fit in, apart from the solid metal plate bit. and the two small black bushes..
any help would be appreciated.
The Metal Plate goes between the diff and the diff carrier to space the diff down.the boy from tas wrote: well i was looking around and and can see where most things are going to fit in, apart from the solid metal plate bit. and the two small black bushes..
The two 1" black blocks go under the tailshaft center bearing mounts.
Daza
Can you keep all the old bolts you remove from your car and give them to me?
