Problems with carby upgrade 1990 Brumby
Installed carby started engine. Lot of coolant in exhaust system and present in inlet manifold. Would welcome a few ideas as to where the problem lies. Many thanks Dave.
1990 Subaru Brumby.
- TOONGA
the standard inlet manifold on the EA81 motor has 2 points where coolant can leak at the heads where the manifold bolts on and under the carby where a water jacket helps the carby on cold starts and stops ice from forming (in what country Im not sure)
Im hoping when you put the new carby on you put new gaskets on as well and yes if there is a black plastic spacer you need one under it and one under the carby and if you had the manifold off you need new gaskets for that as well and I would also consider doing a compression test to rule out a leaking head gasket
hope this helps if you need a gergorys manual its here
showthread.php?t=16439
