does anyone know if cam gears from a ej207 gc8 will fit a ej20k gc8?
cheers dave
ej20 cam gears
Hi and Welcome
A bit more info would help but I'll see if I can help ??
Not sure on the engine codes but we have fitted Metal Timing Belt Gears in direct replacement to the plastic type. We did this years ago to make varible timing gears on the engines that originally came with the plastic type. Just look at the way the keyway on the pulley is setup and if they look the same then you will be ok.. Post some pictures if you're still not sure.
