ECU Fuel Pump Signal
What makes the ECU decide to turn off the fuel pump?
Given that the fuel pressure regulator is vacumm driven, it cant be fuel pressure.
After you switch the ignition on the fuel pump goes for a few seconds and then switches off, is this simply a timed thing? I presume that when you turn the ignition to start, the signal from the ignition switch then tells the ECU to start the fuel pump again, is this correct?
The reason i'm asking is that my ECU won't prime the fuel pump at all. If i provide direct power to the pump it works fine, the relay works as it should but the ECU won't turn it on.
Any help would be much appreciated.
when the ecu gets power it primes the pump for 3-5 seconds
and the pump starts again when it receves a valid timing signal from the cam and crank angle sensor
the start signal dosent have anything to do with the fuel pump as far as i know it has to do with over injection when starting no signal makes the car hard to start
have you checked the error codes
and if you plug the brown connectors together under the dash near the steering coloum the ecu should cycle the pump on and off
how to on error codes
showthread.php?t=14372&highlight=error+codes
Progress update........
Swapped ECUs and the fuel pump primed
Cranked it over but wont start
Sprayed stuff down the air intake - started straight off
Soon as the spray stopped so did the engine
The engine ran 3 weeks ago b4 i rewired the car (complete rewire not just engine loom) so the injectors would appear to be ok, i have fuel, spark etc.
What else could it be
I'm beginning to think its the ECU - thoughts anyone please.
I have spent most of the day searching this site for answers but it is really hard when the search function doesn't accept 3 letter words - ie ECU MAF etc
So if you bypass the fuel pump relay, will the engine start?
If it doesn't, you have a bigger issue, and i'd be looking at the cam and crank angle sensors
- vincentvega
somthing from the realms of racing
some ecus when the realise that the fuel pump is on its way out it will switch to the spare
it does this by determining how much power the pump is drawing when i begins to draw say 14 volts to over come friction cause the bearings are gone, maybe its trying to do this without a spare to switch too??
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
- vincentvega
dose the pump come back on when you crank the engine over
if so do the injctors have a positive supply from the relay on the ecu loom
the injectors are constant positive supply and switched negative through the ecu
Problem fixed
Got another ECU from the wreckers and it started straight away!!!
Thanks for your responses everybody.
The car is an 89 Touring wagon with an ej22. When i got the car the wiring was crap so i decided to do a complete rewire, not just engine loom. Main reason being that i wanted cruise control on the steering wheel, proper temp gauge (installed the lib dash as well) fans switching on when they're supposed to etc etc.
Well it has certainly been a learning curve lol.
My only remaining problem now is the temp gauge (the one i didn't want to have to play with
). As soon as i turn the ignition to on the gauge jumps to 1/3 (completely cold engine) and when the engine starts it jumps to half
I have tested the resistance of the temp gauge sender unit and it is correct.
The gauge was working fine in the donor car so i'm at a bit of a loss. Funds are in very short supply at the moment so i can't afford an after market gauge.
Any suggestions on where to look to try to solve this???
By the way i would have been lost without this website, it really is cool !
Tony
Tony
