Ever thought with our ageing beasts (pre OBDII) that they need some sort of diagnostic panel made up and mounted in-dash, or hidden in glovebox to keep lights to a minimum. Better still, lights to glow when fault arises. Consisting of LEDs to indicate YES we have ignition power at the coil, YES we have power at the fuel pump, incorporate a headlight reminder in it so no flat battery due to door not shutting fully and draining overnight
OnBoard Diagnostics
OBD1980's style
4 plug EA82 MPFI & Turbo ECU's supported 'Subaru Select Monitor'. But im unsure if it is compatible with the current SSM protocol
