Ventilation isn't runing on stage 1
Kralle
Post by Kralle » Tue Jan 26, 2010 3:38 am
Hello guy,
i have a problem in my subi, my ventilation isn't runing on step one, i changed the switch and the ventilator, but there wasn't an improvement. what could be damaged?
Post by Gannon » Tue Jan 26, 2010 6:34 am
It will most likely be the blower resistors, they control the fan speed.
There is a small section on the output of the fan which has 4 wires going to it and it unscrews. You will have to get another resistor block.
Kralle
Post by Kralle » Tue Jan 26, 2010 7:59 am
thank you, but where is the resistor block?
Post by Gannon » Tue Jan 26, 2010 8:27 am
If you look in the area under the glovebox, you will see the blower motor at the bottom (cylindrical metal thing with a wire coming out of it)
Not far from this, is a plug in the plastic ducting that has a square plug with 4 wires going to it. It is held in with 2 screws i think.
Take some photos, post them up and i will point it out. I dont have an L series anymore so i cant take a photo myself
Kralle
Post by Kralle » Wed Mar 03, 2010 4:51 am
now here a picture
you have to know its a LHD subie
Post by Gannon » Wed Mar 03, 2010 5:16 am
Follow the 4 blue wires, and take a photo of what they connect to
Kralle
Post by Kralle » Wed Mar 03, 2010 5:26 am
okay thank you, i think i found what you meant
however heres the pic
Post by steptoe » Wed Mar 03, 2010 9:18 am
My pics are turned off but if you found 3 coils of wire of different thickness of the wire you have found first, second and third gear of your fan motor, top gear is straight through power.
Post by Gannon » Wed Mar 03, 2010 3:35 pm
Yep thats it.
Just go to a wreckers and find another that has the little coils intact
Kralle
Post by Kralle » Wed Mar 03, 2010 4:46 pm
i have a second subie for tacking such parts out of it
Return to “Trouble Shooting”
