Some of you may be aware that I have just fitted an a/c system to the Brumby - see this thread - and I was very concerned about removing the existing mechanical fan and its effect on engine temperature. Well, it looks like my fears have been confirmed. When the a/c is on (both electric fans going all the time) everything is OK, but when it's not on (not usable at the moment) I'm finding that the EA81 is overheating terribly. The problem from my perspective is that those twin radiator fans simply do not come on early enough before the engine has a chance to heat right up towards hot on the gauge.
I would like to modify the system so that these fans trip in much earlier around (or just under) half way on the gauge, instead of 3/4 hot or further. I have done a forum search and found many excellent threads where people have had similar issues but still not found the exact answer I'm after. What I don't understand is exactly what is involved. With the hot climate we have in Brisbane I want to see and hear those fans running a lot more often than they do. Unfortunately, with the hot climate we have in Brisbane, I don't want to pull the a/c and put the mechanical fan back in.
From the threads I have read, it seems that fitting the Tridon TT2041-170 high flow thermostat will help the engine to cool down much better. Will there be a severely adverse impact in winter using this thermostat?
But what about getting the fans to automatically come on at a lower temperature? I do not want to have to manually switch them on from inside the cabin. Does the key lie in purchasing a different thermo switch, and if so, what type? Tridon's website list the TFS 195 switch 90C to 85C. According to a Subaru manual I have sitting here the factory switch is from 95C to 91C. Does this mean a) the fans will come on earlier or b) the fans will run longer when they do actually come on?
Please excuse my ignorance, but even non mechanically experienced people like me recognise the value of proper engine cooling. And with an EA81 that's only just hit 20 000kms, this becomes even more of an important thing to get right.
Thanks in advance.
