One of the callipers removed and the pads (metal composite and new)
The disc and hub both look near new (apparently the discs are 1000km old)
more to come
wrxer they are waiting for you, its funny I was looking at them this morning thinking ah more metal to make wifey angry I then remembered your tracking problem, there are small cosmetic differences and Im not sure about the length but they look the same as the MY armswrxer wrote:toongs, whats the difference between the brumby arms and the lseries ones. will arms bolt into brumby, are they longer, or make track wider or do they bolt onto at different spots.
can i use similar arms in my brumby and get the lseries track width?
apparently there is a residual line pressure valve somewhere at the back, (there is a picture in the gregorys book, it is near the rear exaust?) the old adage "if it aint broken...." the master is the model with one main reservoir and 2 pistons?(standard brumby issue) anyway it works and works well so Im happy, on the highway yesterday I stopped to pick up a traveller and I braked like I normally did the brumby stopped so well I had to coast to him, before I would have gone past him.wrxer wrote: and where is the residual line pressure valve (rpl). normally in the rear output port of master cylinder. did you remove this, or if you didnt, was it a 4 wheel disc master cylinder, if so no wonder it had bad brakes before.
 )Toonga - they're originally from an RX turbo L series. The only touring wagon they would've come from factory was the GT2 like what Chris Rogers started out with for this twin turbo psycho Touring wagon conversion...TOONGA wrote:they are off a 89 l series touring wagon and cost $400 Im really lucky as the rotors and disc pads are near new, (and are in reality as rare as hens teeth well the hubs are)
