I'm having a right bitch of a time trying to remove the crankshaft pulley of my ej22. It's currently out of the car and being stripped down to rebuild.
My main two questions are:
- What are the methods you've used in the past to immobilse the CSP (or any for that matter);
- Where is the cheapest place to get myself a decent length of steel to use as a bad-arse breaker bar?
I've currently got an assistant holding a crowbar in the flywheel to stop the pulley from turning, but I can't get enough leverage with my breaker bar. this method would only work for the CSP anyway, and as i'm stripping down the whole lot I've got other pulleys to get at. The subi manual on here and in my garage both state to use special tools - one says a 'chain wrench', the other a 'cam shaft pulley tool', neither of which can i find at the auto stores around home. Suggestions?
Any and all help appreciated!
Owen.
. Lifted, bars, exhausts... View
Gumtree ad
