Testing Knock Sensor
iananita
Post by iananita » Sat Apr 18, 2009 6:17 pm
Haynes manual says no continuity in EJ22 Knock sensor but mine has 550 000 ohm resistance.
Can someone test their sensor?
I have a knock sensor fault code. Is it a fault in sensor or wiring? Engine running smooth
iananita
Post by iananita » Mon May 04, 2009 6:48 pm
Was getting intermittent knock sensor fault code. Here is the reason. Old sensor(at bottom) had cracked casing. New sensor now in no fault codes.
Knock Sensors.jpg (105.73 KiB) Viewed 3597 times
Post by AlpineRaven » Mon May 04, 2009 9:07 pm
If you're still getting no replies, i'll check mine, i have a spare one in the garage.
tex
Post by tex » Mon May 04, 2009 9:10 pm
Seems to be a common problem and as someone pointed out to me the positioning for them isn't exactly the best! I went through a subaru wrecking yard and couldn't find one that hadn't cracked from the heat!
87 targa brumby (Neglected),
+ others.
vincentvega
Post by vincentvega » Mon May 04, 2009 9:27 pm
this is one part you really shoud replace with a new one.
Take the thing out, if there is any signa t all of cracking it needs to go in the bin.
$140 from subaru. will solve your problem
Joel
Post by Joel » Tue May 05, 2009 10:21 pm
i have heard of people relocating them
checked mine and ofcoarse.....cracked.....:rolleyes:
greywarden
Post by greywarden » Fri May 13, 2011 10:59 am
Cool looks like this one is a better reference than this thread. showthread.php?t=19353/knock sensor function
ooopps sorry no offense lol i will just buy a new sensor i guess that is the best move for me to make because i am not really knowledgeable in testing .
Talasas
Post by Talasas » Sun May 29, 2011 4:31 pm
For the record the Gregory's manual says that they are supposed to have 560k ohm resistance. But they are notorious for cracking, replacing it was a good idea.
Return to “Trouble Shooting”
