Genuine Subaru coolant
G'day guys,
What brand and who is it that Subaru sells genuine coolant (its premix) - is it labeled as Castrol coolant or what?
Thanks
Thanks
Not sure what company makes the "genuine Subaru" coolant, however many of the reputable brands will have a product that is fine to use. Just see what concentration Subaru recommend and buy the one that matches. The Subaru one will be one of the leading brands re-badged with a Subaru sticker / label. I know buying the coolant / oil / brake fluid from a Subaru dealer is very expensive!
Willie.
Canberra
MY06 Forester XT Luxury
MY05 Pajero Exceed DiD
1975 VW L Bug (1303)
Canberra
Yeah they are expensive. I would like to use product close as possible what Subaru uses, that is why i,m asking on here.Willie wrote:Not sure what company makes the "genuine Subaru" coolant, however many of the reputable brands will have a product that is fine to use. Just see what concentration Subaru recommend and buy the one that matches. The Subaru one will be one of the leading brands re-badged with a Subaru sticker / label. I know buying the coolant / oil / brake fluid from a Subaru dealer is very expensive!
- FROG
castrol...............
- d_generate
Just make sure whatever you use is 90+ and don't mix it with any other brand, I usually get the pre mixed stuff but the concentrate usually works out cheaper.
- FROG
says contains ethlyne glycol 50% plus a bittering agent .... so you dont drink too much of it i guess
I believe it is made by Castrol under license for Subaru and is not the same as the anti-freeze/anti-boil Castrol that you could buy from somewhere else i.e. Repco, etc..
I have pulled many Subaru engines apart whilst working in Japan and it amazed me to see how new the water jackets looked (even after 150-200 thou kms). From seeing that first hand, I only use the genuine coolant in my late model Subies and in the earlier ones, I used Techalloy Gold concentrate with De-Mineralized water.
This is just from my experience because there are products out there that I haven't used.
- openflame06
