Ok so i got this EJ22 but it has a blown head. I want to use it as it has done 105xxx k's and get it ready for the l series conversion...
I heard that it is possible to use sti or wrx heads and that give the engine more power? Is that true? Is it a simple question of putting the heads on and everything else is the same? plug and play?
Ok so i'll do the heads, change the Tbelt. Do you guys think i should get a new water pump, or replace the seal? Should i get new head bolts?
Also what else can a change apart from the rings or internals...
thx
Getting a EJ22 ready for the l series conversion... help!!
I might be wrong here, but I think the turbo'd heads has different water channels/flows etc... I'm not sure, I think you can use non-turbo DOHC heads on EJ22 engine...
I'll let someone else to answer this...
What about another SOHC head... I heard a guy used a ej16 heads to obtain more torque and low end power...
Im thinking to get a licensed wagon but do you think i could do it in a unlicensed one and get it on the pits? changing enything else that needs to be fixed.
Does anyone know of a towing wagon, licenced or not in WA going for a rather cheap price??? Can have a blown engine:P
