Does anybody else have problems with EA82 exhaust manifold gaskets?
Cos i do!
It seems a couple of times a year, i have to pull the header off, and replace the gaskets.
Ive been using ACL ones (shiny surface with lots of little dimples) mostly, and have only ever used one with a metal ring in the centre once.
What do you use? More specifically referring the EA82T
Im thinking maybe my flanges arent perfectly flat and are causing the problem
Im open to all suggestions
- discopotato03
Hi Gannon , I've never refitted an EA82T header pipe (so far) but when it really counts I like to use factory gaskets where possible .
I have two here in my hot little hands and their part number is
- GASKET RM 44022GA320 .
They have a metalic crush ring around the inside .
Some people may baulk at paying $17.44 ea but I reckon it's better than doing the job multiple times .
I have no idea if the carby or MPFI NA gaskets are any different but you can be sure that if the turbo engines have special requirements Subaru would have used a suitable gasket .
Not 100% sure but EA82T headers don't appear to have a stainless bellows like EJ Turbo crossover pipes do so there is def scope for different expansion rates of the header and the distance between the engines exhaust ports .
My engine was not rebuilt with a genuine gasket kit but all the manifold and head gaskets are .
The non guenine gasket kit I believe also has flat shiny looking things which are probably quite ok on non tubo engines .
Thanks for highlighting this issue and we'll try to avoid it .
Cheers A .
Cheers A .
Hey disco.... Can you take a picture of your gasket for me please?
My L wasn't a turbo - but same deal, got sick of blowing exhaust gaskets all the time. I then gave the hi-temp silicone a go (the O2 sensor safe type). Apply it one night but don't fully tighten the exhaust stud nuts. Wait til at least 12 hours have past by then do the nuts up good and proper (and hope the studs don't come out, that was my other problem). This worked a treat for me til we hit the exhaust hard and ripped a stud, then there was no fix
Dunno how it'll go with a turbo though - I never used a gasket, just the goo
I used the genuine gaskets when I changed to the MPFI header, no problem since. I did compare it to an aftermarket gasket (from Burson's), and the Subaru unit was much more textured.
Dean.
Dean.
Yeah i agreetimmo wrote: Enthusiasm the missing ingrediant!
It is such a hassle to remove the header pipe cos its so hard to get to the turbo bolts (and the risk of breaking a stud)
I think adrian may be onto something with the contraction and expansion of the pipe. Id also like to have flanges with 4 holes to bolt up to the heads too.
- discopotato03
- discopotato03
All of the gaskets are punched from what they call DSM (Double sided metal) gasket. Some have a 'flame' ring - these are the best ones to get.
If you are constantly blowing / burning gaskets out your mating surfaces are not flat.
A gasket is only as good as the surface it mates to....
http://www.subiparts.com.au
0438 887 746
0438 887 746
Looks like i will be re-designing my header up-pipe then.
What ever happened to the ones you were making Justin?
I have bought 2 new gaskets
Permaseal on top, ACL on bottom
again
These are the gaskets i pulled off
The one on the right is also a permaseal, but i think it has been there longer than the ACL one.
I put them on tonight, and what a pain in the proverbial it was. 2 of the studs stayed in the head so i had to cut the gasket around the stud and slide them in. I wasnt gonna remove the turbo at 5:30 in the arvo
Will see how they go and report my results
again
