RX distributors
twilightprotege
RX distributors
Post by twilightprotege » Mon Mar 23, 2009 9:11 pm
while putting my new engine in, found my disi to be rather dirty, and the vacuum advance/retard thingie was broken. it didnt move when i sucked or blowed through the vacuum hose, and when i took it off and blew through the hose, air just came out the otherside, so obviously the diaphram inside it is stuffed - certainly not good for a turbo engine. anyway, i figured i might as well just try and get a completely new disi so make sure it'll be fine for quite some time.
anyway, can you buy new or reco'd disi's? if so where from, how much? repco etc?
thanks
Post by steptoe » Mon Mar 23, 2009 9:57 pm
I found this out the hard way. Converted to LPG and only took 5 months to discover that gas vapour was, under boost, zipping through this diaphragm and igniting inside the cap turning it into a small combustion chamber and then a bloody backfire.
I bought a new one from Subaru that took about 8 days from Japan
This is the vacuum advance and boost retard unit on the three plug ECU RX L series
Subaru part number is 22301 AA110
steam the label off to reveal Hitachi part numbers 70139684 and 44R83 - 44003
made a good healthy difference even at the eat 20 cent packs of noodles for a month price of about A$270
discopotato03
Post by discopotato03 » Tue Mar 24, 2009 1:23 am
Like most things 3P EA82T I have a spare dizzy and its diaphragm is RS .
Thats not such a bad price for a complete distributor and everything would be fresh .
The one in my engine is much better but not perfect , holds gob pressure but not vacuum .
After the engine goes in if it has timing curve problems I may see if I can locate an old Haltech IG4 programmable timing only computer and wire it into a later 4P CAS type distributor .
The mechanical 3P dizzy can be made to give good results down low or up high but not both at the same time .
Full management like the 4P system gets around the mechanical dizzy limitations .
Cheers A .
twilightprotege
Post by twilightprotege » Tue Mar 24, 2009 8:19 am
yeah $270 is ok, but still a bit nasty. at least it's completely new and should be fine for many many years to come
discopotato03
Post by discopotato03 » Tue Mar 24, 2009 11:17 am
Gee I don't think so , I think it's amazing that you can still buy a distributor that was last in a production car in early mid 1987 .
Possibly to make things cheaper the diaphragm can assembly may have been sourced as a seperate part - if they are still available .
Mechanical/pressure referenced turbo distributors are a special case because often they are designed to advance at varying sub atmospheric manifold pressure and retard with rising positive pressure .
I've been playing with different pressure sources for my 3P dizzy and its impossible to achieve what can be done with an electronically controlled system . Sometimes engines like their ignition to ramp up to a point and even go backwards a touch before increasing further up the rev range . You can't do this with a mech system .
A brand new dizzy will get closer than a worn one so its about as good as it gets in this case .
If I could get a new diaphragm it'd be good .
Cheers A .
cwinter
Post by cwinter » Tue Mar 24, 2009 4:19 pm
Would anyone happen to know the part number for the 4 pin computer, electronic disi,
and if its still possible to get a new one?
Post by steptoe » Tue Mar 24, 2009 5:22 pm
HEY !! Who said anything about that price beng for a new dizzy ?? That was for the diaphragm assembly !! Both my other spares were also stuffed or could only hold five psi then stuffed !!
cwinter
Post by cwinter » Tue Mar 24, 2009 5:45 pm
Sorry my bad.
Still keen to know about part numbers and availability for 4 pin elect disi, though if anyone knows
cheers
Xtreme_RX
Post by Xtreme_RX » Tue Mar 24, 2009 6:32 pm
Advanced Diaphragm Options - They will rebuild the diaphragm for you. The one on the RX is a bi-directional diaphragm. It will cost you about $88
Best bit for us Brisbane people there located in Caboolture (Learjet Drive)
http://www.advancediaphragmoptions.com/
http://www.subiparts.com.au
0438 887 746
twilightprotege
Post by twilightprotege » Wed Mar 25, 2009 12:05 pm
oooh nice. will give them a visit!
Post by steptoe » Wed Mar 25, 2009 12:44 pm
I wish I'd asked before and got this answer. I just chucked one dismantled one out. I think I have another somewhere to send away one day . Ive made a note somewhere in my notebook
twilightprotege
Post by twilightprotege » Thu Mar 26, 2009 9:03 am
taking mine there today - will let everyone know how it goes and the $$$
discopotato03
Post by discopotato03 » Thu Mar 26, 2009 11:44 am
Yes do tell .
Cheers A .
twilightprotege
Post by twilightprotege » Thu Mar 26, 2009 4:38 pm
the guy is working on it now, but since mine was stuffed i really need a picture of the distributor with the cap off so we can see the no vacuum/no boost position of the advance/retard thingie's arm. just like the attached picture, but with the vacuum thingie in place and connected
twilightprotege
Post by twilightprotege » Thu Mar 26, 2009 8:38 pm
anyone??? would be awesome to have the picture by tomorrow morning so the guys can get the thing fixed. once the guy has the placement on record, everyone can benefit!
Post by steptoe » Thu Mar 26, 2009 10:32 pm
Done
I emailed two pics separately to [email protected] at 11:30 PM Thu26/3/2009
hope they help
Jonno
twilightprotege
Post by twilightprotege » Fri Mar 27, 2009 7:12 am
can you email them to me? [email protected] - apparently when i spoke to mike that email address isnt working at the moment
Post by steptoe » Fri Mar 27, 2009 12:57 pm
done at 1:55PM Friday
twilightprotege
Post by twilightprotege » Fri Mar 27, 2009 4:45 pm
thanks jonno, everything done, $75 later.
looks great. told mike that there would probably be a fair few guys from here getting their diaphram rebuilt.
Post by steptoe » Sat Mar 28, 2009 3:48 am
so just what was done to rebuild the vacuum can that photos were needed?
Got a photo of finished product?
