Subie Boys , Lovey80 Resto
- brumbyrunner
- vincentvega
Yes we do. A wire brush ( 2 types, cup and flat to suit where we are up to ) on either a 5 inch grinder which i normally use and rick uses a 7 inch grinder with the wire brush on. Once you have done it for awhile , it is not that hard to use them for hours on end. It would be like anything , if you do it long enough , it becomes easier.vincentvega wrote:Do you use a wire wheel on an angle grinder to take all that paint off?
I dont know how you hang on to it for so long. I hate the vibration from those things!!
Ross
1996 Gen 2 liberty Wagon, manual with L series low range Awd and vlsd .
While Ross was doing some resto work on his massage recliner , i took some more paint of the brumby. Found a little bog.
I will be contacting a couple of the people on the list of cars we will be doing. We wish to shrink the list down from 9 cars. Once the list ends , we are having a break for 12 months to fix our own cars. When i drive in the rain , my feet get wet and i dont have the window down or the door open , just getting in first..lol..
rtcb65
Redneck Rick.
Redneck Rick.
Had some time today to take some more paint off. Picking the places to remove the paint first. As Steve is in the last stretch of the project he is working on. ( the person it is being built for, prefers it not to be put on forum, and have to respect his wishes ) so i am clearing the areas that are to be seam welded and strengthened for the extra power of the EJ motor.
rtcb65
Redneck Rick.
Redneck Rick.
While Ross was out maintaining a couple of elderly peoples lawns , i got a chance to remove more paint.
rtcb65
Redneck Rick.
Redneck Rick.
Ross and i grabbed a wire brush each today and went at it .
This is inside the tray. The stuff in there used as a protector , it comes off but is a little harder to get off than the paint.
rtcb65
Redneck Rick.
Redneck Rick.
Good stuff!
I noticed you've done the same thing as me with the captive nuts - snapped the bolts that hold the bumperettes on the rear of the brumby... I did this on Sunnie and am yet to get replacement nuts and bolts, I'm just glad I can access the rear nut easy enough to replace with a none captive nut.rtcb65 wrote:
Hey Bennie,El_Freddo wrote:Good stuff!
Yer, it has happened to a few of them. Rust builds up on the thread and they wont come out. Break off instead. We will open the area's up and either take the bolt out or cut the nuts off and put new one's in. Then put anti seize or alike to try to stop it happening again.
rtcb65
Redneck Rick.
Redneck Rick.
Spent a couple of hours on the brumby today, removed the spare wheel mount and got the retainer ready for dressing up and strengthening . Also still at it , removing more paint.
rtcb65
Redneck Rick.
Redneck Rick.
Looking good there.. you guys are busy!!
I can't beleive how many spot welds there are holding on that little spare wheel bracket, I'm still in this process!
87 targa brumby (Neglected),
+ others.
+ others.
I am not completely sure, i think there was around 14 , give or take.tex wrote:I can't beleive how many spot welds there are holding on that little spare wheel bracket, I'm still in this process!
rtcb65
Redneck Rick.
Redneck Rick.
Took some more paint off her and some of the ute tray stuff. ( What ever it is . A coating used as help protect it). It takes awhile .
rtcb65
Redneck Rick.
Redneck Rick.
The light at the end of the tunnel is visible . About 80% of the paint is off the brumby now.
rtcb65
Redneck Rick.
Redneck Rick.
Got into it again today, removed some more paint. Looks like it is time to hang up the 7 inch grinder and get the 5 inch out, so the spots the 7 inch cant get to, will be reached. Here are some over all pics.
rtcb65
Redneck Rick.
Redneck Rick.
