Heres the big question:
What sort of money would I be looking at to do the EA to EJ convertion??
Or should i just do the timing belts and water pump and just wait for the engine do died in a big way later?:???:
:p:mad:
;):D:-D:???::p
keep in touch see how you go.jsubie wrote:Thanks for your advice guys I will just replace the timming belts and w/pump for now.
At least I should have the car back on the road by Monday/Tuesday.
]jsubie wrote:I was on way home yesterday the car was running well. I turned a corner and the car just seemed to splutter out like if I ran out of fuel. i still had half a tank, I check all the usual things anyway turn the engine over with the dizzy cap off and found the rotor was not turning. So i guess that the timing belt has snapped. On top of that the lifter and the water pump need to be done too.
G'day syro,syro75 wrote:G'day I had a similar thing in my L wagon on Friday it was a wet day and i had been in a bit of water the car was running like a treat. I got home had a cuppa and went to go out but the car wouldn't start it turned no worries, after a bit of searching i discovered the fuel pump was not getting any voltage. Why would this be the fuse is good and there is power at the box.
HELP
