Brumby Wheels
Wozzy
Brumby Wheels
Post by Wozzy » Fri Apr 11, 2008 10:31 pm
Just joined the forum and need some advice. I picked up a Brumby ute from a mates farm and doing it up and want to put on some nice wheels on it. The tyrepower man said I can't get anything that will fit the 4x140 stud pattern. What's out there to get a better look? Not too keen on just steels rims but want something arounf 15 x 6 inch. Not going off road.
Post by Gannon » Sat Apr 12, 2008 7:25 am
Welcome to insanity.. ah.. er.. i mean AUSubaru
How much are you willing to spend?
There are about 6 options when it comes to wheels for old subarus.
1. Performance Superlites - Around $200 a wheel
2. Speedy Desert Rats - Around $90 a wheel
3. Scorpions - $185 a wheel
4. Peugeot 504 Alloys - Find them at a wreckers, but be careful, some of these wheels use metric tyres, very expensive
EDIT
5. Crossbred Conversion Kit - Allows fitment of any Impreza/Liberty/Outback/Forester wheels
6. 6 Lug Conversion - Allows you to fit wheels of large 4WD's like Hilux, Pajero, Patrol ect. Technically not legal
Thanks rtcb65 for the last 2
rtcb65
Post by rtcb65 » Sat Apr 12, 2008 7:39 am
Somewhere on the forum , it says about the 5 stud conversion so you have the choice of wrx wheels also. Then there is the choice of redoing the hubs to suit 6 stud as in cruiser, etc . Not sure on the legal side of this way though.
rtcb65
Redneck Rick.
Post by AlpineRaven » Sat Apr 12, 2008 7:58 am
I think it would have been much easier to have 5 lug conversion and use Liberty or Impreza/Forester wheels - there is a sh*tload of them everywhere. Even can use 16" on your Brumby and would look good.
Bumpty
Post by Bumpty » Sun Apr 13, 2008 8:15 am
Suparoo wrote:Welcome to insanity.. ah.. er.. i mean AUSubaru
EDIT
That is a great reply^ :D
Go the 5 stud conversion for more options, and if you change your rims often enough, you'll have a bigger range... but if you want to keep it kinda near as original, jus look at those 4 stud rims.
subie_1st_timer
Post by subie_1st_timer » Sun Apr 13, 2008 9:04 am
those speedy wheels are way over priced, can pick them up for less than $60each brand new if you shop around
BRUMBI
Post by BRUMBI » Sun Apr 13, 2008 9:44 am
i got mine for $62 in i reckon they look pretty good brand new even if ya not 4wding
84 MY Sportswagon
92 Brumby
87 Rx Turbo
Post by Gannon » Sun Apr 13, 2008 11:39 am
subie_1st_timer wrote:those speedy wheels are way over priced, can pick them up for less than $60each brand new if you shop around
Thats 1/3 the price of Scorpions, but scorpions have the correct offset and they look good too.
I'd like to try another group buy of 14" steel wheels with a larger offset so they sit in under the guards on the l series.
Thalass
Post by Thalass » Sun Apr 13, 2008 12:46 pm
Why are the six-studs illegal?
ChPLAT
Post by ChPLAT » Sun Apr 13, 2008 1:36 pm
Cus you have to drill holes which changes the integrity of the hub I assume.
Past rides-
1989 Brumby
Current ride-
MY06 Liberty 2.5i Sedan
kona480
Post by kona480 » Sun Nov 30, 2008 3:27 pm
Suparoo wrote: 4. Peugeot 504 Alloys - Find them at a wreckers, but be careful, some of these wheels use metric tyres, very expensive
wouldn't all 504 rims be the same ( metric or normal ) how do you know which it is?
why are they expensive? ( tyres )
are they hard to find? ( tyres )
LTurbo
Post by LTurbo » Sun Nov 30, 2008 4:29 pm
kona480 wrote:wouldn't all 504 rims be the same ( metric or normal ) how do you know which it is?
The wheel above is not a 504 rim. It is a 505 GTI rim, the 504's never came with 15" wheels, although the 504s do have good 14" wheels that fit
The 505 wheels that are metric, are something like 390mm, which sits in between 15" and 16" (imperial) wheel sizes. It is very hard to get metric tyres, people get quoted around $300-400 a tyre. The size of the rim should be stamped on them some where, also if it has tyre on it, just check the tyre size to see if it is imperial or not.
kona480
Post by kona480 » Mon Dec 01, 2008 11:33 am
LTurbo wrote: The 505 wheels that are metric, are something like 390mm, which sits in between 15" and 16" (imperial) wheel sizes.
are the ones in the picture metric?
i have found some of the same rims for sale but need new tyres
Phizinza
Post by Phizinza » Mon Dec 01, 2008 5:29 pm
If you buy Desert Rats with tyres you will quite often get them priced around $65. Without tyres and you should be up for $75.
daza
Post by daza » Mon Dec 01, 2008 6:38 pm
Danny5816
Post by Danny5816 » Thu Jan 29, 2009 12:15 am
were can i get the 6 stud conversion
ChPLAT
Post by ChPLAT » Thu Jan 29, 2009 11:25 am
You can get the 5 stud from Crossbred http://crossbredperformance.com
Otherwise the six stud way is a home job and also illegal unless maybe its for solely off-road use, i dunno.
Past rides-
1989 Brumby
Current ride-
FROG
Post by FROG » Thu Jan 29, 2009 12:50 pm
go the crossbred .... tried and tested
nncoolg
Post by nncoolg » Mon Feb 02, 2009 6:17 pm
