How many kms does your Subaru have?
I want to bring this topic up about your Subaru - How many kms does it have on the clock?
I'll start with mine, Its 1996 Liberty GX wagon, 5MT AWD now at 284,000kms, compression is very good & doesn't blow smoke at all & going strong - will last for long time!
- Captain Obvious
EJ20 turbo in a 89 GX wagon, who knows how many k's on the shell and im pretty sure the motor ks are 256xxx had the head gaskets and seal done last year but other than that its all going strong!!!
bryan
bryan
i have a friend at work with an old bunky assed gen1 liberty wagon with the odo reading over 475xxx last time i looked..but got no idea whats been one or not on it
Before I retired my RX turbo it had done around 675,XXX Kms. 2nd motor & gearbox, 3rd clutch.. Body rusted through on most of the major joins so it has been retired....
http://www.subiparts.com.au
0438 887 746
0438 887 746
- RetroLover
Holy shit! Some of those figures are more than the average life of a Taxi Cab. Also shows the superior build quality of Subaru engines.
1989 Subaru Leone GL, FWD, EA82 5MT: 200,500km. "Dormant"
1991 Subaru Liberty GX, AWD, EJ22 5MT DR: 176,500km. "Working Project"
Spose if i where to ever sell the Liberty Wagon ever, it would featch for a bit with the low kms on it.
Yeah, if they havent been heavy footed and pushed around, well serviced then they do last forever.RetroLover wrote:Holy shit! Some of those figures are more than the average life of a Taxi Cab. Also shows the superior build quality of Subaru engines.
I've seen Subarus (from MY - L series to Liberty/Foz/OB etc) over 500,000 under 700,000kms but havent seen over 700,000kms to a million.
Ruby Scoo - 1988 L wagon - original gearbox, rear diff just swapped for a welded item... 370,000km with the following changes:
Original carb '82 was seriously cooked by previous owner - cracked heads and cylinder!
Converted to MPFI '82 by myself, while in the process of this found out about this website (and the EJ options...)
Rebuilt a second MPFI with new piston heads/rings/oil pump rotors and seals/gasket kit. Shaved heads and a now dodgy paint job.
That lasted 9 months before the radiator let go and cooked that engine.
Now running an '84 carb model EA82 all jerry-rigged into the EFI system to work. Got an EJ lined up for it.
Rear bearings are REALLY SHAGGED!!! Front one's are probabily not that far behind. The rear left moves a good cm or two on the outer edge of the tyre when jacked up off ground, rear right is not as bad as this - got replacement items to go in next week.
Rear suspension bushes will be replaced next week too.
And due to lack of lift + the new welded rear, the floor pan is looking like a piece of "art"
177k on my Brumby...everything was original afaik when I got it with 158k on the odometer, the MPFI box in it I have no idea on the km's done but I'd expect at least that much as it wasn't in great condition. New clutch, water pump, and gasket set when the box was changed, and it's used a few litres of oil since.
Dean.
Dean.
- FROG
385 100 on the lib when i sold it, engine rebuilt at 385 000 and set hgs at 280000(before my time)
wanky has 340k on the clock, but hasnt had a speedo since i lifted it, so add another 25-30ish, and its had 14s on it since new, so she really has almost 400k on the body.
turbo motor has about 95k on it. Nothing on this car is original except for the body panels and interior. I tell ya, she looks pretty sweet still!!
liberty has 120k on it, pretty piss weak haha, but it is only a 2001.
