1991 Liberty Series 1 or 2 ?
- caboolture
Trying to work out what my 9 month 1991 Liberty GX awd Wagon is.
Is it a series 1 or 2 ? does have a gen 1 or 2 tag and will original gen 2 1996 outback rear struts/coil bolt straight on. It has a 3 '' lift.
1991 gx 3" lift 16" gt Forester alloys,215/65/16 outback struts and pedders raised springs, Turbo motor,gearbox,diff,brakes,bonnet etc now transplanted
from your sigpic it would appear to be a gen1 s2
 VER7 STI  (FOR SALE) & RIP     EJ22 AWD LEONE
Hunter S. Thompson
Hunter S. Thompson
Check out this thread mate > http://ozliberty.com/forums/showthread.php?t=11939
I think you should put a thread up in the 'my ride' section, would like to see more shots of the lib
 (may help us tell you what you have
Also, if it is a s2... Yes gen2 (96 - [beginning of 98]) outback struts will swap straight in, rear and front.
- RetroLover
- chubby37
the car you have is a gen 1 series 2 for sure....the outback front struts will fit it the front but the backs wont as the springs are tapered...you will need to go to a shocky place and get some to fit...fulcrum do them.....or the other option is put in 2 or 3 inch stut tops and give it a suspension lift that way...not to sure is you could put your springs and tops on the outback rear to fit?
