Starting issue - auto outback
i would, but i bought the battery in kalgoorlie, for a super duper special deal through my company with westrack, and the battery has no stamp nothing on it, and because its not used for work purposes i could get into trouble..hehehe if thy find out i put it in my car..lolFROG wrote:try them out for warranty anyway most batteries are date stamped, be worth a go anyway
good luck Dave
dave
- FROG
ahh well then maybe not lol
cant swop it out into another work vehicle
btw what is it ?
just out of interest
btw what is it ?
990 cold cranking amp, specifically for westrac, so its catapillar, for all their smaller tractors and trucks, after days of deliberation this is what we decided would be best for my setup.
obviously not ..lol
dave
obviously not ..lol
dave
- Captain Obvious
need 2 people for this, but put a multi meter on the solenoid terminal for the starter but leave the wire connected and measure the voltage, if there is low volts there say 6 that your problem, its not pulling the contacts on far enough, mine has/was doing the same thing, you can do a patch by adding a relay.
use the starter wire to activate the relay and run a feed from the battery to the starter.
bryan
bryan
captain, this is exactly the problem i was having...and i have done exactly what u have just explained:), the starter motor problem has now been solved its now just my dicky battery which im displeased about but im obviously gonna have to fix it regardless
cheers
dave
cheers
dave
- stamp_licker
dud batteries happen.I brought a battery once and it wouldn't hold volts so i rang the mob i brought it off ,said they were new owners.So i rang the manufacturer and they said the battery was 2 years old and had been sitting on the shelf.Doesn't help you much though.
Hope you get it sorted.
Building a hardcore postie:D
- vincentvega
if i was talking about my MY yes....AndrewT wrote:But you're using an EA starter yes? Because of the adaptor plate and EA gearbox?
but thinking about it i dunno if he has heard my Lib start. altho i did take it to the pines that time
Wagon is no longer....
Im not gonna sift through all the stuff in this thread Dave... Call me if your still having dramas. You should have called me in the first place... doofus.
Dave
Dave
issue resolved
thought i fixed it
turned out the alternator was charging at idle, but not when revving
thought i fixed it
- vincentvega
i found out the hard way at work
1.5 tonnes of water tank on trailer,,, middle of boggy sand, 200 odd metres from nearest hard road
turned car off
never started back up :P
and like i said..it was charging at idle. it was even chargins at 2000 revs,,, anything HIGHER and it was not charging...was draining battery, and according to the subaru workshop i went to today, they put it on an analysis machine....and said up untill 2000 revs it was charging to proper capacity, but faster it span, the bushes slowly detatched from the centre bit
dave
turned car off
dave
the fix is sweet **** all atm....really
dave
dave
untill i find the energy to get mine rebuilt or a new one, alex spare isnt a very good alternative caus its different..but will do to get me to work and back
dave
dave
