Fuel consumption WRX 2013
Posted: Wed Nov 25, 2020 8:49 pm
Hi guys,
Apologies in advance for the long winded post.
I have posted in a different forum but figured it never hurts to garner a few different opinions and hope that someone had a similar issue and found a solution.
Full tank 98 premium fuel and at 270km the warning light was coming up.
Fuelled up and only took 44 litres to fill. Basically 280km 44 litres of fuel. Rough calculation about 15-16 litres per 100 km. Head unit displayed 13.4 litre per 100 km.
Not sure if this is common. When the warning light was displayed on my previous car, I would have to fill within 10-15km otherwise i would run out of fuel. It did happen once
I obviously didn’t buy this car for its fuel economy but is this normal?
Stock standard, and have probably only given it a hit once since I fuelled up. Mainly city driving.
I followed some advice and removed the AFM and used mass air flow cleaner. I re installed and it was quite erratic to begin with. The display was indicating 22 litres per 100km. I drove conservatively for about 20-30km. It has now settled to 12 litres. I understand the figures on the display are not going to be 100% accurate.
I haven’t seen it below 13.4 since I have owned the car, about a month.
In your opinion does this indicate the AFM was/is faulty? Is there a chance it will settle further to where it should be, which from I have read is around the 10-10.5 mark, as 13 is still a little high?
Have only just serviced the car, hoping I don’t have to spend more.
Thoughts, similar experiences?
