Clutch Replacement 1989 Subaru Brumby
Engine, gearbox, diff & driveshafts
Denzil
Post by Denzil » Thu Dec 09, 2021 4:32 pm
Got the Engine out, so I thought that I would do a Clutch Replacement. My question, is there a Clutch Replacement Kit that you would recommend that I use. Don't want to go as far as using Ceramics.
Denzil
Re: Clutch Replacement 1989 Subaru Brumby
Post by steptoe » Fri Dec 10, 2021 12:45 am
standard supply issue usually whatever you get choice of. Exedy is often trusted. Many seem to just be brand packaging of a few manufacturers. Careful on what aftermarket supplies on clutch release bearing carrier. Being 1989 will be 225mm but again be careful using 1989 as year model as some parts systems try to supply 225mm kit for EA82 L Series and they diffr on step heght required and the hole between finger tips of clutch pressure plate diapfragem spring plate
Denzil
Post by Denzil » Fri Dec 10, 2021 1:11 pm
Thanks Steptoe, been looking at Exedy Clutch Kit FJK-6817.
Return to “EA Drivetrain”
