Tutorial: Converting EA81 to EDIS
Posted: Sun May 29, 2016 11:42 am
Here it is at last
For anyone thinking about converting their older gen Subaru to distributorless ignition or wondering how difficult it is, hopefully this thread will tell you all you need to know.
I'll start by saying the electronic distributorless ignition system (EDIS) is a system that uses a crank angle sensor, toothed trigger wheel and electronic control module to fire a modern style coil pack as wasted spark ignition.. There is also another aftermarket ECU which then attaches to this system which allows you to control the ignition advance/timing via laptop and easy to use graphical user interface. The benefits of this system are:
- Precision ignition timing that can be dialed in to perfection for your engine
- No moving parts than can wear out and introduce slop into the system
- Modern coil pack with two individual coils inside, can run bigger spark gaps without a problem
-No more old, worn out dizzy, crusty dizzy caps or worn out rotor arms, no more points to adjust
Call it bringing an old engine into the modern era just a little bit
The downsides are that the parts as far as I can see aren't readily available in Australia (mainly the Ford EDIS module that is required) due to the donor cars not being available in Aus. The parts are readily available over the internet and ebay, you may just be paying a little more and waiting longer.
Parts list:
- Ford EDIS module. Can be purchased from this website along with the sensor and coil pack.
- VR sensor. There is one in the kit linked above but I didn't like it, it's too long and difficult to mount nicely on an EA81. So I bought an Audi sensor off ebay such as this. It has 3 wires but only 2 are used for this EDIS conversion.
- Ford Fiesta coil pack (see link above)
- 36-1 toothed trigger wheel. This is available from the above link or ebay but they are expensive and not quite the right size for EA81 3 groove pulley IMO. I drew one up myself in autocad and got it laser cut, so PM me if you want one, cost is $20 plus post)
- Megajolt ECU. I bought mine here with soft rev limiter. Be sure to add a serial tuning cable to your order so you can plug it into a laptop.
- Ignition leads. This one I got stuck on because the Ford coil pack as above has different terminals to the old dizzy. There is a small pin in the center, which needs a matching female part on the ignition lead which extends past the rubber boot to reach down into the coil pack terminal. I bought the right terminals off ebay here and if you do the same you will also need an ignition lead crimping tool. You can buy these as dedicated tools but since I already had a ratcheting crimp tool with interchangeable jaws I was able to find some ignition lead crimping jaws. Make no mistake - making your own ignition leads is a PAIN IN THE A$$!!! If you can source leads that have this terminal already on them, or if there is a coil pack that has the same terminals on it as the old dizzy this would be a much better option.
- Twin core shielded cable. This is for the lead between the sensor and EDIS module, and also the EDIS module and Megajolt ECU. It has to be shielded and it is very important to connect the shields properly to avoid interference in the signals going to the ECU/EDIS module.
- You'll also need other cable for wiring everything up, a relay is nice for switching the whole circuit on and off with IGN. If you use the same sensor as I did you might like to get this plug also as it means you can just plug your newly made harness into the sensor. If the sensor ever fails or is broken it is then a simple task to unplug it and install a new sensor. If you get this plug you'll also need a proper crimping tool so best thing is to head down to Jaycar and get their ratcheting tool and some jaws for insulated and non insulated terminals.
Other links:
Megajolt installation guide - Read, read and re-read this guide until you have a good understanding of the system. Also helps to print out a few choice pages to follow while you are under the bonnet.
Megajolt configuration software. You will need this little program on the laptop to talk to the Megajolt ECU and program the ignition map.
I think that's about it for a parts list
It looks daunting and/or complicated and maybe it is. It's really not that bad though, I slowly collected the bits over a month or two as I needed them. Now you've all got a list to easily follow but I had to track everything down piece by piece which was not fun
This conversion isn't a weekend job or something you can quickly throw together and go wheelin'
It's quite a major modification for the engine but I think the benefits make all the effort well worth it.
That's enough of that, time for some pics and tutorial
Parts list:
Other links:
