3D Printed Replacement Parts ...
Collection of automotive design / construct projects by Bantum ...
Moderator: Bantum
Horn Button ...
Post by Bantum » Sat May 29, 2021 3:22 pm
Ha - Could be ... :razz:
Was originally made for these but :
Cheers, Bantum ...
Re: 3D Printed Replacement Parts ...
Post by El_Freddo » Sat May 29, 2021 11:12 pm
Why are there captive screw three sections? That’s what I based my thoughts on!
Looks good, or is that the sample unit you based the design from?
Center Cap ...
Post by Bantum » Mon May 31, 2021 3:52 am
Yes, made a direct copy of the original :
Idea is to strip the metal parts & reuse them on the printed base where the old is past muster ... :/ ( broken or deteriorated )
You can download the file here : https://www.thingiverse.com/thing:1478397
Cheers, Bantum ...
Post by Silverbullet » Mon May 31, 2021 7:45 pm
Nice work Bantum, 3D printing has done so much good for the issue of old, brittle, non-existent (new) odd little plastic parts for cars and restorations.
I'm wondering, would you offer your 3D printing services for outside jobs? :razz:
The rear windscreen demister in my wagon doesn't work, I think the element is cactus. I've got an idea for a PTC heating element and a little blower fan mounted in the tailgate but would need some custom ducting/joiners to pipe the warm air to the base of the window. I'll do the design work, but I don't have a 3D printer, could I send the files your way?
Re: Printer Service ...
Post by Bantum » Tue Jun 01, 2021 3:58 pm
Yes had thoughts of doing something like that ( am in the process of build a 3D printer ) but not looking to go into business as there are too many regulation / tax implications for me, so it will be just a 'hobby' thing done in my spare time for now ... :/
Speaking of updates, just got this to put the printer in ... :)
Cheers, Bantum ...
Post by Silverbullet » Wed Jun 02, 2021 11:06 pm
Is that a fume hood? Good idea...
Understood, I might have to look into getting myself a 3d printer at last! ;) Have thought about it a few times but could never justify getting one.
Printer Enclosure ...
Post by Bantum » Thu Jun 03, 2021 1:33 am
Yep it has several functions, helps to keep the heat in and stable & stops the fumes spreading ... ;)
( the fabric is supposedly fire retardant - yet to test it, may still need to add a filter somewhere )
Printers have come down in price too, got this for under $400 ( spent more on peripheries but )
If was doing mass produced stuff, I'd go for a more industrial type ... ;)
( they will cost more mind you )
Cheers, Bantum ...
Door Pulls ...
Post by Bantum » Thu Sep 02, 2021 4:25 am
Did a test print on the Door pull :
Still more work to do ... :/
Post by TOONGA » Thu Sep 02, 2021 11:25 am
nice it looks like the 41 year old sun damaged ones on my sedan ;)
Good to see you experimenting though keep it up.
Dust cover & End Cap ...
Post by Bantum » Sun Sep 19, 2021 5:21 pm
Did some more 3D stuff:
Roof Rack End Caps :
Door Dust Cap :
Might want to print them in flexible material ... ;)
Cheers, Bantum ...
Door Pull Trim ....
Post by Bantum » Sat Dec 25, 2021 4:08 am
Well it's been released :
https://www.thingiverse.com/thing:5161635
See what you make of it ... :biggrin:
Cheers, Bantum ...
Printer upgrades ...
Post by Bantum » Sun Jan 30, 2022 4:08 am
Well this lot finally arrived :
& opened :
Unpacked :
& the Duck :
Just got to work out how to install it now ... :/
Ciao, Bantum ...
Post by Silverbullet » Fri Apr 08, 2022 9:32 pm
That's a nice little lot there Bantum 8-) is that upgrades for your printer or an entirely new printer? Almost looks like stereo-lithography kind of printing gear...
Re: 3D Printer Parts ...
Post by Bantum » Sat Apr 09, 2022 2:37 pm
Thanks, haven't got round to installing all of it yet.
BQ hot end is lighter & supposedly can handle higher temperatures ... to be mounted on one of the tool plates.
The Hermit Crab ( & tool plates ) is so I can interchange printer head with other devices like laser / cutter parts.
Idea is so I can do engraving & cutting stuff on same machine.
Have also been upgrading the power /control boards :
Whether it works or not tis yet to be determined ... :/
Ciao, Bantum ...
Let there be light ...
Post by Bantum » Sun Feb 12, 2023 4:10 am
Well I need to be able to see things better - so got me something to light up the print bed : * Edit - link broke ... :oops:
testing :
And few more bits added to the parts bin :
Got to get back to finishing the printer now ...
Ciao, Bantum ...
Door Pull Test Print ...
Post by Bantum » Sun Feb 12, 2023 4:18 am
Well I did a thing & got this :
& back side :
Will have to do some more tweaking to correct some of the errors found - bit thin in some places + clips didn't print correctly ... :/
Welcome feed back from others who have got round to printing it ... :)
Cheers, Bantum ...
Post by El_Freddo » Sun Feb 12, 2023 8:43 am
That looks quite good in the pics Bantum!
How will that material fare in the cabin of a sun soaked vehicle, would it be likely to warp?
Keep up the good effort!
Print longevity ...
Post by Bantum » Sat Jun 17, 2023 4:14 am
Depends on what its printed with - ABS, same as original - PETG, yet to be tested, but should hold up just as good if not better.
Will have to leave a sample out in the sun for a couple of years to check on suitability.
Cheers, Bantum ...
New Digs ...
Post by Bantum » Sun Apr 05, 2026 3:55 am
Since I've moved about 3 times in the last bit, I haven't got round to setting up my now 'old' printer ... :cry:
( I'll get round to finishing it sometime ) - So I've been using a newer Bambu H2D printer :
https://au.store.bambulab.com/products/h2d - The technology has advanced & improved ... :mrgreen:
So I've been working on a few projects that I can direct you to :
- Forester fog light bracket : https://www.thingiverse.com/thing:7180762
Will post up some more when I get round to it ...
Ciao, Bantum ...
Post by El_Freddo » Fri Apr 17, 2026 1:40 am
How good are the Bambu lab printers?
We have the X1C and H2D at work. The X1C seems to be a bit better I reckon with the lidar that checks the first layers for issues. The H2 will sometimes keep printing when the first layer screws up. And I’m not sold on the quick release nozzle, good for change/cleans when needed but I think the fixed unit in the XC1 is possibly better in the long term.
Apparently they just released the X2C that’s dual nozzle and not much more than the H2D.
Oh, hang on, I’ll have to double check the H2D - it might be a P model now I think about it. I’ll get back about that next week.
Looking at the pics as they loaded Bantum, the interior door handle trim is now being reproduced by a few ppl that you might have seen already. I guess that’s the downside and positive of 3D designs etc.
Return to “Bantum’s Works”
