XV Ute ...
Collection of automotive design / construct projects by Bantum ...
Moderator: Bantum
Do you want XV-UTE?
Maybe
30
81%
Maybe
2
5%
Maybe
5
14%
Total votes: 37
Progress ...
Post by Bantum » Thu Apr 04, 2013 3:54 pm
Tried using Sketchup for a bit & came up with this :
Wheel Nut
Slow progress I know, but learning as I go ... :)
P.S. - Does any body know how to get the 'Rotating Image' thingy uploaded along with it onto the 3D Warehouse Site ?
Cheers, Bantum ...
Edit : Updated link ...
Post by 60766244 » Thu Apr 04, 2013 7:18 pm
Congrats. Learning curve is steep and downhill with Google Sketch so you'll work it out fairly fast I am sure. Seems good. :)
I'm building my "Ideal" shed on Google Sketch atm before I convert it to blueprints and it's a workout. :rolleyes:
As for the 3D image rotator I find it works better in Google Chrome browser but dies out on other browers (Firefox, Safari, Chromium, etc) It may have to do with the flash/java scheme of things...
Delayed ...
Post by Bantum » Thu Apr 04, 2013 10:52 pm
Ha - just went back to see if it had worked :
Just takes a while for it to load ... :)
Post by 60766244 » Thu Apr 04, 2013 11:45 pm
Bantum wrote:Ha - just went back to see if it had worked :
Playing with the animate functions or a hellova lot of screenshots of the 360 degree thing?
It won't load more than a thumbnail to me. :p
Post by Bantum » Thu Apr 04, 2013 11:59 pm
I just right clicked on the 3d image on 3Dwarehouse and saved it to here ... ;)
Yeah, not sure exactly what I did to get there though, as I thought it was an automated process when you uploaded to the site - appears to be working now ... :)
Cheers, Bantum ...
Update ...
Post by Bantum » Sat Apr 06, 2013 6:09 pm
Ok - I've done a bit more :
Look here for the 3D Model : Subaru XV Wheel
Will start working on the base of XV -Ute next ... :p
Post by 60766244 » Sun Apr 07, 2013 12:26 pm
Great skills mate. Good patience too. Your XV Ute will be a sight to behold.
Wanted ...
Post by Bantum » Sun Apr 07, 2013 4:49 pm
60766244 wrote: ... Your XV Ute will be a sight to behold ...
Thanks ... :)
P.S. - Has anyone got some under body shots of the XV engine bay, suspension, brakes ?
I'm Looking to model them in Sketch up ... :)
Cheers, Bantum ...
Post by El_Freddo » Fri Apr 12, 2013 6:28 pm
Full on mate! Tidy work on that sketch up - is it an easy program to use and do you need to download it or is it net based? I'm thinking of using this in one of my classes :D
Keep up the good work as always!
Post by 60766244 » Fri Apr 12, 2013 9:03 pm
El_Freddo wrote:Full on mate! Tidy work on that sketch up - is it an easy program to use and do you need to download it or is it net based? I'm thinking of using this in one of my classes :D
Agreed! It's downloadable for free onto any computer, just google, "Sketchup Download" and in 5 minutes you can get playing. :)
More ...
Post by Bantum » Sat Apr 13, 2013 12:33 pm
El_Freddo wrote: ... Is it an easy program to use ? ...
Sketchup is relativley easy if you compared it to AutoCAD, although it does have less functions & can be a bitch trying to get compound curves to work ... :-x
El_Freddo wrote: ... and do you need to download it, or is it net based ? ...
Yep - free down load ... :D
El_Freddo wrote: ... Keep up the good work as always ! ...
No worries, will do ... ;)
P.S. - Will post an update shortly ... :p
Cheers, Bantum ...
lovey80
Post by lovey80 » Sat Apr 13, 2013 4:52 pm
Bantum wrote:Found some more chopped images ...
That forester chop with about 200mm or so longer wheel base and the same on the tray, diesel with a really low LR box and I'd buy one for sure.
Update ...
Post by Bantum » Tue Apr 16, 2013 2:10 pm
Ok - I managed to get some 'virtual' work done on the ute over the weekend, here are the results :
Note : Added brake to the wheel ... :D
Then mocked up a drive line :
Note : Haven't quite got all the details right yet ... :shock:
Add : Any body got some photos of the under side of a XV ?
And finally a first draft of the side panels :
Note : Not finished yet, still need to go over it again to 'iron out' the kinks, gaps & missing bits ... ;)
Still loads more to do though ... :rolleyes:
Cheers, Bantum ...
Edit : Updated links ...
Update ...
Post by Bantum » Fri Apr 19, 2013 9:20 pm
Done a bit more to the front end :
Note : Tidied up the side panels & added a front bumper bar, still needs a bit more work though ... :p
Next task will be looking at the rear end ... ;)
Cheers, Bantum ...
Edit : Fixed Link ...
Post by 60766244 » Fri Apr 19, 2013 11:38 pm
Stirling work as always!
Add ...
Post by Bantum » Sun Apr 21, 2013 4:52 am
Done a little bit more ... :p
Note : Now have added the rear end, although I haven't quite finished the tail lights ... :D
Add : Also I might have to revisit how the tailgate folds down, as it interferes with the bumper ... :(
Next ... I'm thinking will be looking at the Cabin ? ... :wink:
Cheers, Bantum ... :mrgreen:
Edit : fixed link ...
Post by El_Freddo » Sun Apr 21, 2013 9:49 pm
Holy crap! Have you got an XV to be taking measurements from or are you just using photos??
Looks awesome!
Small update ...
Post by Bantum » Tue Apr 23, 2013 4:12 am
El_Freddo wrote: ... are you just using photos ? ...
Yep, and then some creative licence ... :)
I would'nt go measuring it though, but it should be a close approximation. I'll add some screen shots later of the example used to 'follow', which were loaded in the background ... ;)
Meanwhile, here is a small update of some details added to the rear end, see if you can pick the improvements ... :p
Cheers, Bantum ...
Progress ...
Post by Bantum » Thu Apr 25, 2013 2:16 pm
Done some work on the Tail / Headlights :
I'm looking to intergrate them into 3D model ... :D
+ Some background images used for modeling :
Edit : Sorry some of the image links are lost - will see if can find replacements ...
Post by 60766244 » Thu Apr 25, 2013 10:40 pm
Amazing dedication to the cause. Looking very, very nice!
Return to “Bantum’s Works”
