Bantum's '82 Touring Wagon ...
Moderator: Bantum
Roof Rails ...
Post by Bantum » Mon Jul 06, 2026 11:51 am
Latest bit work done ;
Finished putting together the roof rails :
Note : 3d print is availble on Thingiverse ... Link : https://www.thingiverse.com/thing:1478397
& Installed them :
Next on the cards is the graphics ... ( will have to move it first so I can get access all round )
Cheers, Bantum ...
Re: Bantum's '82 Touring Wagon ...
Post by El_Freddo » Mon Jul 06, 2026 5:58 pm
Looking good Bantum! Will you ever throw some luggage up there or too worried about damaging the paint?
And I see you’re operating out of a shipping container, that would be tight (but better than nothing)!
Post by Bantum » Wed Jul 08, 2026 12:54 pm
Will eventually put something on it - not sure what yet as it will have to be light weight & not too bulky ...
Yep its a bit tight in the continer, a move is on the cards ... Engine has to come out & things fixed to be ready for SubiNats ... :)
Ciao, Bantum ...
Clean up ...
Post by Bantum » Sun Jul 19, 2026 9:29 pm
Bit more progress on the wagon - Finally got round in moving it to a suitable 'garage' to work on it ...
Did a bit of cleaning up & removed the Engine ...
Next will be some tidying up & installing the engine swap ( from Brumby )
Cheers, Bantum ...
Post by El_Freddo » Fri Jul 24, 2026 7:51 pm
Bantum, I didn’t realise your touring wagon was auto - maybe I missed that detail earlier.
I like the spray can cap on the carby, or is this a 3D printed number?
And what’s with the pipework on the PS rack? It seems to go everywhere and looks painful if you ever needed to pull the rack out!
Testing ...
Post by Bantum » Mon Jul 27, 2026 10:35 pm
No, its the old the paint can lid trick ... :)
Yer the pipe work to power steering is a bit of a spagetity nightmare, hoping for now that it doesn't leak to much ... :/
I'm in a bit of a quandry though - The motor I took out of the wagon had power steering, the one I'm replacing it with from the Brumby dosen't - Problem is the vaccum line takeoff on intake to master brake is in a slightly different location, not allowing the power steering pump to fit - so am looking to relocate the off take ...
Brumby Engine :
Comming in hot :
So anyone got a solution suggestion / recommendations ?
Ciao, Bantum ...
Post by El_Freddo » Fri Jul 31, 2026 6:28 pm
That brake booster port was an issue with Sunnie the Brumby and Redback Brumby.
My solution was to swap it with a port on the other side of the manifold where there’s a blank and extend the brake booster hose.
This didn’t solve it straight up as the blank still rubs on the PS pump - I ground that port and blank down sort of smoothish to clear the PS pump.
That’s from memory, there might be some pics in either of their build threads. Most likely in Sunnie’s I reckon.
Hope this helps, I don’t have time to go find the post for you sorry.
More Issues ...
Post by Bantum » Sun Aug 09, 2026 2:15 am
So after looking at the port off take on the other side, I think your right that will be the best option - as its a direct swap, just need to find a longer vac hose ...
& after getting the tank out and giving it the once over - found its full of crud / varnish / rust ? - so will need to get a few new compontents - tank / fuel pump & float sender unit ...
I have a second tank that's near identical, just from a later model which has an extra vent pipe - plan is to block it off ...
Anbody know what this blue can thing is ? ( Connected to vac lines )
Ciao, Bantum ...
Post by El_Freddo » Sun Aug 09, 2026 11:04 pm
Bantum, that blue can thingy is related to some part of the PCV system from memory. Follow the large pipes under it to find out where they go.
If no larger pipes, I have no idea!
It sucks ...
Post by Bantum » Fri Aug 14, 2026 8:36 pm
Started to transfer air con compontents ... ( from Brumby to Wagon )
First step is to de-gas : ( contecting up the lines )
Then use a Vacuum pump to suck every thing out :
Just need to transfer it all over to the wagon now ...
A/C Brackets ...
Post by Bantum » Wed Aug 19, 2026 1:59 am
Spent the day transfering A/C components :
Drilled out & removed the lower A/C brackets from Brumby : ( + a coat paint too )
& installed them on the Wagon :
Still needs a bit more tweaking to get it all sitting right :
More to come ...
Cheers, Bantum ...
Post by El_Freddo » Wed Aug 19, 2026 9:01 pm
Looks good mate! What’s that little box thingo on the centre upright in front of the condenser?
You’ll love the AC I reckon. Might need to turn it off going up hills :lol:
Subyroo
Post by Subyroo » Thu Aug 20, 2026 9:13 am
Will turning it on going downhill give him more speed though. :roll: :twisted: :twisted:
Return to “Bantum’s Works”
