Bantum's '05 Forester ...
Moderator: Bantum
Headlights ...
Post by Bantum » Sun Jan 11, 2026 2:57 am
Well its been a busy few weeks after Forrie suffered some hail damage - ( end of Nov 2025 )
So decided to tackle fixing a few issues along the way ...
Pulled apart the light body & cleaned up :
Some new hardware to go in :
Repairs / repaint done to chrome bits :
3D print parts for LED Strip :
Testing :
& spent few hours polishing the f*ck out of the lens :
more to come ...
Hailed ...
Post by Bantum » Sun Jan 11, 2026 3:20 am
Also did a bit of dent pulling to see if this gadget worked :
Still need to do more :
Plan is to wrap it after I've done repairs :
Image to come ...
Also added a drain ( from plumbing dept @ Bunnings ) to back of headlight :
Not sure if that will solve issue of leaky seal, will see ...
Mini spots ...
Post by Bantum » Sun Jan 11, 2026 3:32 am
Found a LED light that actually fits between the grill slats :
So set about making some brakets to hold them in place :
And a WIFI control unit to run it :
Comming together nicely :
Awaitng a few more bits to complete the asembly & will update when I have it in hand ...
Cheers, Bantum ...
Re: Bantum's '05 Forester ...
Post by El_Freddo » Sun Jan 11, 2026 7:37 pm
Neat work as always Bantum.
I’m keen to see the wrap you go with!
Subyroo
Post by Subyroo » Mon Jan 12, 2026 9:57 pm
G'day Bantum, what is your verdict on the dent puller?
Dents ...
Post by Bantum » Sun Jan 18, 2026 5:30 am
The Dent puller has worked so far, but is a bit messy / tricky to apply with hot glue sticking to everything & if your'e not carefull will burn fingers ... :oops: + if the paint is not well laid down it will also lift, have a bit more work to do & will post some after shots when I get round to it ... :biggrin:
Subyroo
Re: Dents ...
Post by Subyroo » Sun Jan 18, 2026 11:30 am
Did not want to hear about the paint lifting, looks like I will have to get the paintless dent removal guy to do the job. I don't have the confidence in my ability if it's that easy to damage the paint work.
Thanks for your feedback, it is appreciated.
Post by El_Freddo » Sun Jan 18, 2026 3:46 pm
How do you go about removing the glue after you complete your dent pulling? Hopefully it’s an easy task removing that glue.
Looking forward to some before and after pics!
Re: Hot Glue Removal ...
Post by Bantum » Sun Feb 01, 2026 4:16 am
From internets :
"To remove hot glue from car paint, gently heat the glue with a heat gun to soften it, then carefully scrape it off with a plastic scraper or credit card, loosening it gradually; follow up by cleaning the residue with isopropyl alcohol or white vinegar on a microfiber cloth and finish with a wash and wax."
Have yet to try it - so will get back to you on results ...
Ciao, Bantum ...
Post by Bantum » Wed Mar 25, 2026 4:11 am
Added to the collection of parts :
17x7" JJ - B22 - M in J - 55 offset ... Add: just wighed in @ - 9kg ... !!!
Need to find suitable tyres next - Got any recomendations ?
Ciao, Bantum
Post by El_Freddo » Wed Mar 25, 2026 7:12 pm
Black ones :twisted:
Seriously, whatever you’re comfortable paying for these days I reckon.
Those rims are a clean style - a mate recently brought them to my attention as he fitted his to a slammed brumby he’s building. I would like the flat 5 spokes from the early GT foz for my brumby some day.
I’m guessing these will be going on the foz since this is the foz build thread…
Post by Bantum » Thu Mar 26, 2026 3:18 am
Ha - yrp black it is ... :p ( although you can get colourised )
Could'nt pass on them, as I'd been looking for ages - something nice to suit the Foz ... :biggrin:
Add : I just weighed them - heavy buggers are they @ 9 kg each ... !!!
I Keep an eye on FB market place, as stuff comes up on there all the time ... ;)
Awaiting next pay day ... :oops:
Cheers, Bantum ...
Clean up ...
Post by Bantum » Sun Jul 05, 2026 1:23 am
From my last 4wd trip I discovered the wheel well was all drty & rusty so pulled out the spare & cleaned it all up :
& gave the well a quick coat of paint :
Not sure where all the water was comming from but - will have to check it regularly to see if any water comes back ... :/
Oh & tested the jack stand print out :
Held up ok & just fits ... :)
Cheers, Bantum ...
Return to “Bantum’s Works”
