XV Ute ...
- Bantum
Download ...
For those wanting to print one of these babies out, I have now uploaded it to thingiverse :
Download here : http://www.thingiverse.com/thing:946554
Slowly progress is being made on the scanner, so will be able to do some more on this project when completed ...
Ciao, Bantum ...
Ciao, Bantum ...
- Bantum
Copy Cat ...
Someone has had the same idea ...
Add : found here : https://www.pinterest.com/pin/27584616439487732/
Ciao, Bantum ...
Ciao, Bantum ...
- Bantum
Extended ...
Thanks Bumpty ...
As for the extended rear - all in good time, got to finish this one yet ...
Progress has slowed since last time I looked, do hope to get a sponsor on board sooner or later though.
Ciao, Bantum ...
Ciao, Bantum ...
- Bantum
Update ...
Time for a bit of an update, as it's been a while since I've worked on this ...
Took the paper model out for its first showing the other day :
Didn't win anything but ...
Was doing some research on an updated front end, something like the look of the 'KenStyle' as shown elsewhere on here.
Might see if I can get them loaded up on the model ...
P.S. - I may also have found a willing hand to make the full size prototype ...
Will post more when I have something concrete confirmed ...
Ciao, Bantum ...
Ciao, Bantum ...
- Bantum
Go Fund Me ...
Started a funding page :
https://www.gofundme.com/subaru-xvute
Will be interesting to see if anything comes of it :
Ciao, Bantum ...
Ciao, Bantum ...
Did you win the lotto mate??
Looks like a good bit if merchandise there!
Updated front end could be interesting. Have you thought about extending the tub to have a bit more of a rear overhang and a more useful tub?
Next could be a 4 door variant with longer wheel base to keep the rear end in the middle of the tray
Just thoughts though, I an only imagine the effort needed to produce anything like this!
- Bantum
Things to do ...
Nuh - I wish - that would help pay for a few things if did win ...
Still got to finish what I started ages ago, so not even considering doing any of the other stuff you mentioned until I've done with these :
( may come back to update )
P.S. - That list doesn't include all the work that needs doing for my Brumby as well ...
Ciao, Bantum ...
- Finish the 1/10 scale model.
- Finish 3D model. ( with updates )
- Finish Display Drawings. ( with updated front end )
- Finish Presentation Banner. ( also with updates )
- Fundraising for a full scale version ...
- Drawings / notes for the conversion ...
Ciao, Bantum ...
- Bantum
Re: XV Ute ...
Well its been a while, No news to report on project but just went back through all the thread pages & fixed up all the broken links where I could, still few missing ... :/
Cheers, Bantum ...
Cheers, Bantum ...
- Bantum
Re: XV Ute ...
Well its been a while since I've done anything on this, so nothing new to add there.
Did find some LED's & EL wire for the model ... ( yet to work on them but )
But have finally got myself a 3D Printer to play with, so will be able to print stuff ...
More here :
https://photos.google.com/share/AF1QipM ... d2OUZqX3Z3
Just got to finish putting it together now ...
Ciao, Bantum ...
More here :
Ciao, Bantum ...
Re: XV Ute ...
I hope it came with a very detailed and accurate Owners/Construction Manual.
Re: XV Ute ...
Cool piece of kit Bantum! What did that set up back, a couple of grand and then some at a guess!
- Bantum
Re: 3D Printer ...
The 3D printer came with basic assembly instructions & there's a on line site ... TBA.
Haven't added up the total cost, but the main part was around $400 mark. Will have to do a break down to see where I'm at.
The goal here is to be able to print with ABS/PETG for the more unobtainable model components. ( Light buckets, Door mirrors, etc. )
Next step in finishing the Tamyia XV Ute model is to get all the printed parts finalised & get some painting done.
Cheers, Bantum ...
Cheers, Bantum ...
- Bantum
Let there be lights ...
Well I've been busy getting these bad boys drawn up :
- Bantum
Print Time ...
Finally getting them Printed :
Dunked in Die :
Plus Test Fitting :
Still a bit more work to do in putting the LED's in place.( am also missing some components )
Cheers, Bantum ...
Dunked in Die :
Plus Test Fitting :
Cheers, Bantum ...
- Bantum
Let there be light ...
Added some more LEDs & got them partially installed ...
Still a bit more to go on completing the install ... :/
Ciao, Bantum ...
Ciao, Bantum ...
Re: XV Ute ...
Good effort Bantum! Lots of attention to detail that will pay off once it’s all done!
- Silverbullet
Re: XV Ute ...
Looks like the kind of car you'd work on when it's too cold and wet outside for the real thing
Good stuff Bantum, watching with interest.
