Big red brumby
Moderator: Rumbl1n
Post by El_Freddo » Wed Aug 22, 2012 5:05 pm
Rumbl1n wrote:so my next mod is to put airbags under the back my dad has a pair that came off his one tonner so im hoping we can mount them where the rear diff stops are located (because of the 4" lift there is quiet alot of room under there)
let me know what you think
I've looked into this on my L series. I'm going to make a plate that mounts from the swing arm closer to the diff so that the air bag is located in line with the chassis rail above. I might have to re-route some lines associated with the fuel tank but I'm ok with that.
The air bags I've got to play with have been donated from Tweety and are like these:
I've got to make up a top and bottom bracket to fit it in then run the air lines to a suitable point to air up and down as needed. I think it should be a sweet setup once completed!
Mitchhsj
Post by Mitchhsj » Wed Aug 22, 2012 5:19 pm
ahh air bags would be great. what would you do for a compressor? i have seen a few mates turn there aircon pumps into air compressors that work quite well and can turn them on and off on the run, one mate has a old 20L gas bottle under his back seat for a storage tank.. works great and i hear its easy to do.
Post by El_Freddo » Wed Aug 22, 2012 5:48 pm
Mitchhsj wrote:ahh air bags would be great. what would you do for a compressor?
You don't need an on-board compressor for air bags. You use a valve setup like a tyre to pump each airbag up to the same pressure once the suspension is raised to the desire level.
If you have a set of air bags that are continually being adjusted you'll need an onboard compressor. But that's not the case for us.
Mitchhsj wrote:i have seen a few mates turn there aircon pumps into air compressors that work quite well and can turn them on and off on the run, one mate has a old 20L gas bottle under his back seat for a storage tank.. works great and i hear its easy to do.
It's something I'd like to do. Just search for endless air. Problem for me is lack of room!
Mitchhsj
Post by Mitchhsj » Wed Aug 22, 2012 7:54 pm
yes i guess your not needing them all the time, just for camping.. yes the little wagons don't have much room..
scriptchip
Post by scriptchip » Wed Sep 05, 2012 11:25 pm
MY mate owns a 92 liberty gx with air bags all round, adjustable.
came out stock, maybe could merge that system ?
~Subaru brumby 1990 - 14's , alloy bullbar , tow bar , 1/2inch rear diff bash plate. .... so far.
~ 2000 Outback - street project
Mothers vehicles.
2012 foz
1985 L series
Return to “Rumbl1n”
