Bianca's Camshaft
- Willy Fisterbottom
My parts man from Penrith Subaru (going back to the 70's) told me otherwise. My N/A EA81 hydraulic lifter engine has the 3 piece pushrods and no lock tabs on the adjusters. My EA81T has the one piece pushrod and lock tabs on the rockers.
http://www.willyweather.com.au
- Brumby Kid
My pushrods have end caps that fall off and I can adjust the rockers
Steptoe what do you think about my valve clearance? What do you reccomend?
do what I did ....thought about it......the valves are only going to ride if there is no clearance and less than no clearance (tight) - correct ? Allowing for possibility that it may get hotter than normal op temp (gaps may get smaller or does metal expand when hot ? or expand enough to close the gaps ?) so, prepared for quick rocker adjusting I got engine to op temp, whipped the cover off and set them on one head to 4 thou each, cover back on, back to op temp, whipped other side off, did same . 14 years good enough trials ?
Last pair of heads just fitted up to B3 took numbers off tag off my 20/60 cam - 6 & 8 thou cold. Yet to drive it, still, noise amps in tin rockers
- Brumby Kid
Ahh too easy, so no damage if too tight. Just going to have to work out what an appropriate size is now.
