Bianca Body Work
murta123
Post by murta123 » Tue Oct 23, 2012 6:20 pm
Oh sweet as yeah I'm having trouble with my stereo at the moment just can't get it tuned right. I only really want it to make the cab quieter. I just want all the work on my brum finished so it's just a Clean brum
Through ideas at me if you have any mate I'm happy to hear wat you've done eg tyre size suspension exhaust size etc
Cheers Glenn
Brumby Kid
Post by Brumby Kid » Tue Oct 23, 2012 7:27 pm
Well ill update the engine thread later when I'm on my laptop.
HEAPS of updates. I'm a little slack
That should give you a few ideas ;)
Cheers Cam
Dads Car: 02 Impreza WRX STi
Brumby Kid
Update
Post by Brumby Kid » Thu Nov 29, 2012 9:30 pm
Right
New bullbar
Lift kit almost installed completely
Brake goodies. Drums shimmed and pads shimmed to match. And new cylinders.
New front discs and pads. Just standard and bendix general ct.
Then I lashed out and got braise lines with an extra 2-3 inches. :)
Oh and painted my wheel arches with sound deadner/ stone chip.
Weber is almost on. And I am very lasy updating this :(
Cheers Cam
Post by El_Freddo » Thu Nov 29, 2012 9:33 pm
Good stuff Cam, especially with the braided lines - You'll love them.
I hope that the extra length on the rear isn't too much. On Ruby Scoo I went with an extra 3 inches to match the lift kit, I reckon I could have gone with either 1.5 or 2 inches on the rear and been fine. Hindsight!
Will you be servicing the master cylinder too? I kind of wish I did with mine, but it's working fine - it'd just give me that piece of mind ;)
Great stuff though!
Brumby Kid
Post by Brumby Kid » Thu Nov 29, 2012 9:49 pm
Havnt thought about it yet. What would I do? And what about the brake booster?
I tell you what, trying to get 20 year old brake lines is hard without wrecking the hard line bolt thingy.
Post by El_Freddo » Thu Nov 29, 2012 10:22 pm
Brumby Kid wrote:Havnt thought about it yet. What would I do?
Either get a new brake master cylinder or have your current one re-conditioned - much like an engine's cylinder they hone it out and replace the piston for a slightly larger one, a new set of seals, a lick of paint and you're on your way!
Brumby Kid wrote:And what about the brake booster?
What about it? :P
Seriously, the mob that did your brake lines should be able to service the booster, although I'm not sure that is needed :???: Someone will know, hopefully they'll share.
Brumby Kid wrote:I tell you what, trying to get 20 year old brake lines is hard without wrecking the hard line bolt thingy.
This is part of the reason why some spend the time to replace these too! You can buy pipe bending and flaring kits to make new hard lines just like the factory ones. I don't have time for that and I don't think our roads create the corrosion that warrants this type of work - unless it's a show vehicle!
Brumby Kid
Post by Brumby Kid » Thu Nov 29, 2012 10:51 pm
That sounds like hard work. I haven't damaged the nut too much. If they are dead il take them to my brake shop.
Ok so vacuum booster doesn't need anything. Could get the cylinder done. Ok.
Thanks Bennie
Cam
Return to “Brumby Kid”
