Vortex build:)
Post by guyph_01 » Sat Sep 17, 2011 6:30 pm
Little update...,
Cleaning stage:
Before
After
Before
After, Interior trim
Rear Seats, Unfortunately i can't do much about the cracks on the top seats or the sun faded trim but they did come up much better:)
Also cleaned the door trims. Have sent them to get partially redone. I'll post pics when they come back:)
Post by steptoe » Sat Sep 17, 2011 7:25 pm
you could spray grey paint on the browny foam to hide a bit more ?
Post by guyph_01 » Sat Sep 17, 2011 9:17 pm
Its a blue trim but yeah maybe, i'll try and see. Thx:)
Post by NachaLuva » Tue Sep 20, 2011 12:34 am
guyph_01 wrote: After, Interior trim
Awesum job on the trim! How on earth did you get em coming up so good?
With the seats...seatcovers? lol :rolleyes:
Post by El_Freddo » Tue Sep 20, 2011 10:48 am
Good work Guyph!
Maybe save up and get the seats re-trimmed to solve that cracking problem on top of the rear seats - get the fronts done too so that everything matches.
Looks like it might just scrub up to be a great little restorer!
Post by guyph_01 » Tue Sep 20, 2011 1:47 pm
nachaluva wrote:Awesum job on the trim! How on earth did you get em coming up so good?
Plenty of carpet cleaner and 2 good wash with the karcher pressure cleaner:)
El_Freddo wrote:Good work Guyph!
Yeah thats too expensive, I'm going with The front WRX seats so i won't need to re-trim them and selling the front seats:)
Post by guyph_01 » Thu Sep 22, 2011 12:21 am
Starting to put Swampy back together:)
As everything was out i laid some RCA, power wires for an amp, a stacker for the future sound system:)
Also started a cut and polish on the paint. Can't afford a respray so will clean and touch her up as best i can:) Done the LH side and rear. Will attack the rest tomorrow after Uni.
Post by guyph_01 » Thu Sep 22, 2011 12:25 am
Also unfortunately found coolant on the passenger side:( So i put a U hose on the heater pipes. I don't really feel the urge of getting that dash out and plus summer is coming. I 've done the heater core on my L series, My bro's liberty but the vortex seems to trickier to get that dash out:(
Ohhh well.....
coupe
Post by coupe » Thu Sep 22, 2011 7:18 pm
Hey Guy
the dash is quite straight forward to remove , there are only 8 bolts and take off the steering wheel first. all the wiring is attached to the fire wall and there are only minor things to move.
Try some Cargo " metalic sealup first it will fill the hole in the heater. and not corrupt the rest of the system.
Cheers Pete
Use The Fork Luke
Post by guyph_01 » Thu Sep 22, 2011 8:57 pm
Cool, but i still don't have the motivation:( Maybe next year when i do the WRX conversion:D
mud_king91
Post by mud_king91 » Thu Sep 22, 2011 10:09 pm
wish i could be arsed finding the inspiration to do something like this
Post by guyph_01 » Fri Sep 23, 2011 2:33 am
Looks like i need turbo gaskets for the vortex. I think its the uppipe gasket. Anyway, where can i find them? I had no luck at the auto shops:(
Mr i know everything, plz help:)
Post by steptoe » Fri Sep 23, 2011 8:17 am
Genuine. The head to exhaust pipe are dear but quality, the turbo to cat pipe - 4 in stock in Oz two days ago. Up ppe ?
mud_king91
Post by mud_king91 » Fri Sep 23, 2011 8:23 am
i think he means intake pipe... tho all my turbo,s just had a rubber tube connecting it to the intake manifold
Post by TOONGA » Fri Sep 23, 2011 8:54 am
guyph_01 wrote: Mr I know everything, plz help:)
Which one? :)
would say Frog would be your best bet
Tweety
Post by Tweety » Fri Sep 23, 2011 10:35 am
It may well have an exhaust leak....but that sound is awesome.
Now I know why Bennie (El Freddo) is in love with it....I think he has the EJ revving sound on his ipod....
Post by El_Freddo » Fri Sep 23, 2011 11:03 am
Tweety wrote:Now I know why Bennie (El Freddo) is in love with it....I think he has the EJ revving sound on his ipod....
That sounds like a good idea tony for those odd times that I'm either having withdrawals or can't afford fuel at that time.
I do have a video of the exhaust on youtube under the user name of "elfreddoandrubyscoo" if you want to check it out :mrgreen:
Guyph, progress is looking good mate! I reckon you should just pull your thumb out and fix the leaking heater core - much easier with the seats etc out already, plus I bet it needs a good clean in behind there!
Then there's that other thing of you needing to do it before winter again when it NEEDS to be done, not HAS to be done!
my 10c
Post by steptoe » Fri Sep 23, 2011 11:02 pm
While you have seats out - does the Vortex have air ducts to rear seat passengers footwell? like all sedans since 1984 ?
Post by guyph_01 » Sat Sep 24, 2011 3:40 pm
steptoe wrote:While you have seats out - does the Vortex have air ducts to rear seat passengers footwell? like all sedans since 1984 ?
No mine doesn't...
Well 2day i removed the exhaust and turbo to get to the gaskets. Luckily I started to soak the nuts with WD40 since the past two days and the bolts came out easy:) Turns out the gaskets were still ok.
This is where the leak was coming from..... lol, clean cut!
So i'll go to an exhaust shop on Monday and get some new gaskets or maybe use the old ones:p
Post by steptoe » Sat Sep 24, 2011 7:12 pm
Good old EA82T !
Return to “Guyph”
