Page 4 of 7
Posted: Sat Mar 17, 2007 2:55 am
by KERAZY
TW83 wrote:Do you mind me asking his name or who did the conversion.
oh dang. bit late but..
Jamie Buszan.
he didn't do the conversion.
Posted: Tue Jun 05, 2007 2:25 pm
by 98choppa
didnt know where to post this but here goes?!....... Lseries 4wd wagon.........
ive converted my gen2 lib. to twin turbo now i have an ej22 sitting in the shed
seems this might b a good motor to drop on my L series gearbox since the 1.8 is getting tired
need some help before i start un bolting things!..................................
im in newcastle and want to get hands on an adaptor plate and start playing..
can i get one round here or should i get some aluminium and make1?
how much does a piece of plate cost???
the motor is from an auto too, will the ecu still work running a manual driveline?
last but not least,can i bolt a 2.2 litre into a 1.8 litere car,then blue slip, see you later... happy driving?................any catches??
some other questions to come id say, any ideas?
cheers
Posted: Sun Jun 17, 2007 4:52 pm
by Too Many Rubes
Hi all, I'm putting an EJ22 into an L series and I want to run it on straight LPG. It would be so much easier if it had a dissy rather than coil packs, so I can throw the ECU in the bin. Anyone know of a conversion to fit a dissy?
Thanks, John.
Posted: Sun Jun 17, 2007 5:25 pm
by BaronVonChickenPants
Brumberty has done this exact modification to his Wonder Brumby (plus an SC14 but thats a different story) he used a dizzy from a Fiori but unfortunately it's a points dizzy.
Apparently there's a ford escort dizzy that fits too.
Very early impreza's came in a mega poverty pack version in some remote/3rd world countries that actually had an ELECTRONIC dizzy, theres are unbelievably rare though, you would be looking for an EJ15, 16 or 18 1995ish impreza that was never delivered to australia.
Brumberty has been looking for one of these for yonks with no real luck.
So short answer is yes it can be done.
Jordan.
Posted: Sun Jun 17, 2007 9:00 pm
and again, steve rising sun was the originator of the dizzy stuck on the head trick for the EJ.
I am 'contemplating' an EJ somewhere in my life on LPG. thinking ECU is a bummer and so are points. maybe there is an electronic ignition kit for Fioris ?
Prefer to go simple IMPCO stuf without ECU, next option be landi renzo with its V05 computer tacked onto ecu.
Is there a gear on an EJ cam that drives the dizzy on RH side head at the rear or is that a mod steve does ?
Posted: Tue Jun 19, 2007 8:55 am
by discopotato03
What about having a play with various distributors to mix n match , somethings bound to work .
Cheers A .
Posted: Tue Aug 07, 2007 11:36 am
by Dan.
How will a l-series g/box cope with a ej22 convo?
Posted: Tue Aug 07, 2007 12:04 pm
Dan. wrote:How will a l-series g/box cope with a ej22 convo?
Should cope alright if you don't thrash it, like anything, look after it and she'll be right.
Many board members run the EJ22 with the standard box, some are even running the standard box with the EJ20G... That's the easiest way to destroy an EA box if your not careful...
Posted: Tue Aug 07, 2007 12:05 pm
by BRUMBERTY
jono wrote:and again, steve rising sun was the originator of the dizzy stuck on the head trick for the EJ.
Hi jono missed this the first time round, Its just a port with a cover plate, drill a hole and fit a seal.
Very simple, I can shoot a photo to you if you like.
There is escort elecrtonic dizzys available, chooks teeth though.
I have a conversion kit from points to electronic...cost me 220 smackers.
(for the Fiori dizzy)
There is even an option of quad cam dizzy access, I have an image of one somewhere, options..I love that lego.
Posted: Tue Aug 07, 2007 5:44 pm
Yeah Matt, as always, a photo is worth a thousand words. YES PLEASE, for us all .So there must be a redundant drive gear on the back of the camshaft ....
Posted: Wed Aug 29, 2007 10:05 pm
by Learner
gee just read the whole thread and still feel like i couldn't do the job. i've never done anything to a car before but i did want to try. now i have a lseries touring wagon and would like an ej22 in it. would u guys recomand i should give it a shot? i might do my beetle first as it does sound easier than fittign on in the wagon.
it would help if som one has a step by step how to site
Posted: Mon Sep 03, 2007 4:31 pm
Learner wrote:now i have a lseries touring wagon and would like an ej22 in it. would u guys recomand i should give it a shot?
If you've got some mechanically minded mates, i don't see why not, it will be difficult at times and you may feel like giving up, but if you get through it you'd have completed a massive achievement.
I'd also look into legalities of a 2.2 ltr dropped in place of a 1.8 ltr for vic, i'd be interested to hear that you can do it - my thinking is that its 10% of the original capacity that you're allowed to go up to...
Check it out anyway, i could be wrong.
Posted: Tue Sep 04, 2007 10:16 am
by AndrewT
I would not recommend it at all unless somebody else is doing it and you are just lending a hand.
If you have not done anything to a car before then a complete engine conversion isn't really a good way to start (unless you have other cars and you aren't relying on your L series as transport!).
If it's just a project car then definitely go ahead, its a great way to learn exactly how your car works.
Posted: Wed Sep 19, 2007 9:57 pm
by Gannon
I was just wondering if anyone has tried to fit an EZ30 H6 into an l series?
I was reading somewhere on the net that the EZ30 is not much longer than the EJ20, because the timing chain in the H6 takes up a lot less room than the timing belt of the H4, the two engines are of similar size.
Remember, they squeezed the H6 into the Liberty that was designed for the H4.
Surely somebody has thought about it.
Posted: Wed Sep 19, 2007 10:19 pm
by Alex
ive thought about it, but never digged into it...
keen for some idea's though ;)
Posted: Wed Sep 19, 2007 10:26 pm
by Matatak
wuldnt that be for discussion in a new thread called something like "Fitting an EZ motor into an L series" :D jk tlak all u want ill just read
alex u shudl consider upgrading the donk in ur liberty with one...not ur wagon lol
Posted: Tue Dec 04, 2007 10:14 am
by persepter
Hi guys, I'm from Russia and this is my huck'n nats XT with EJ20H:
http://reviews.drom.ru/subaru/alcyone/11928/
Posted: Tue Dec 04, 2007 4:44 pm
by BrennyV
persepter wrote:Hi guys, I'm from Russia and this is my huck'n nats XT with EJ20H:
some good pix there pity i cant ready anything ;)
so ur running the single range box on there?
Posted: Tue Dec 04, 2007 6:02 pm
by persepter
BrennyV wrote:some good pix there pity i cant ready anything ;)
Haha, becouse it was writen by russian bear =)))
For the first time there were EA82T and 3speed autotrans. Before this engine died (antifreeze get to oil, rusty "пробка's" in the heads, thanks previous ouner, woman, water is not the antifreeze!!! :mad:), my trans seys "byebye" to me. I changed it. And 2nd died with the engine.
After that I get EJ20H with 260 hp and 5sp manual trans fulltime S/R, it was it summer 2006, and 3 month I lived in my garage.
By the way, this trans died 2 month ago, thanks god I could get another one. This why these trans is 4d in these car =))) Ya, I like to burn ;)
You are write, my trans is single range full time 4wd and difflock, which is not working, I dont make the vacuum for it. Dont look on the button 4wd, its not from this trans :rolleyes:
Posted: Mon May 26, 2008 12:43 pm
by tex
Is anyone familiar with the series 1 brumby and the engine bay because I'm wondering if you could fit an EJ in there!
