crossmember mounts
crossmember mounts
I herd the angle on the crossmember mounts is slightly out when dropping an ej20 into an l series does anyone know anything about how to make the wedges you need to put between the crossmember and engine.
Cheers Rowan
Cheers Rowan
- FROG
- Brumby Kid
No need!made24x4 wrote:does anyone know anything about how to make the wedges you need to put between the crossmember and engine.
Just use brute force and ignorance! Along with a massive hammer! Bahahaha
Im sure some would, dont overlly sugest it though.
Cheers Cam
Just buy them from RSR555 He sells them quite cheap:) Will save you time and troubles.
showthread.php?t=19020
or as i did, just file out the mount slots abit longer.
had no issues doing this.
(but i was running STi group N engine mounts which are stiff and strong as fjck)
if i was doing it again id definately use wedges tho. Paul RSR's seem to be the goer.
