Brumby/ MY ignition switch wiring query
Posted: Sun Jun 06, 2010 11:38 pm
Hi all, got a 1991 Brumby re-motoring effort underway for a while now and have been wondering why my EJ22 conversion seemed to have come unstuck. Put in a good though untested '91 Liberty motor, did all the little fiddly things I have learned here on ausubaru and all seemed fine until it came to the best part... that first fire up. Yeah, right!!! Turned into the worst part. Everything clicking, throwing in, turning over vigorously, no bloody go! Hmmm,... no spark and no fuel. Checked ecu pins for power repeatedly, all earths are earthed and all sensors are good, just won't fire up. Nothing!
Put in a complete uncut Liberty front wheel drive loom to see if it will start on that and it did! Eureka!!!! OK, it works on that so cut that loom down and did a better job of it than the first effort, then installed it again. Wired it in exactly the same as my first effort and no go again. Hmmm. When I used the loom uncut it was using a Liberty ignition switch but when I tried to get power from my Brumby switch it wasn't getting power to the ECU (and hence no power to ignition, pump or ECU itself) in the start position.
I had to put in a relay to switch full time fused power to the run/ accessory position wires in order to use a key start and stop setup. Did try a small diode to do the same or similar thing but that had too much back feed so kept the starter operating, would have been good if it had worked properly though.
I did a search for similar problems that others may have encountered but all I could find was reference to using a separate or remote start button or having a switch on the dash for power to the ECU circuits.
Others must have had this problem with carburettor fuelled cars, either MY or L series versions with an EJ conversion where there is no power (as in 'cut out completely') in the start position but comes back if the key is released? I know why it does this as the starter circuit wiring goes to the bypass setup on the coil to give a solid spark under load on a 7 volt coil and through resistance wiring under running conditions.
How have others got around this problem? Maybe an ignition switch from an injected L series? I'm over it now but would be interested to know other peoples thoughts and experiences in this little problem, may even be able to do away with the relay presently used.
Cheers,... Col.
Cheers,... Col.
