EJ into L series "how to" write up
Post by El_Freddo » Thu Oct 08, 2009 6:15 pm
G’day all.
This write up is designed to help those who are after information for dropping an EJ series motor into an L series Subaru. While the write up is heavily weighted to my experiences it will not answer all your questions, particularly if you’re using a late model EJ – wiring may be slightly different in the later models and where a factory immobilizer is involved this will need to be retained. I hope that you do find an understanding of what’s involved and save you asking some questions later…
First of all you need to decide how you are going to do the conversion:
- Do it yourself or with help from others/have a mechanic do it for you
- Adaptor plate or EJ gearbox or shove the EA box into the EJ casing
- Donor vehicle/halfcut/gather the parts
-EJ18/20/22/25 – put a decimal point between the two numbers and you have its capacity in litres. Eg – EJ18 = 1.8 litres in capacity.
In terms of parts – if you’re going to collect the parts yourself the best bit of advice I can give is in terms of the wiring: Make sure you get the wiring that matches the ECU and that of the engine, this is the wiring that plugs into the loom near the battery, it will be two or three plugs and passes under the intake manifold to the various sensors and injectors. Best practice would be to get the sensors too as I’m not sure about the difference in sensor wiring between the years/models if any.
Other than the wiring, the rest of the mechanical bits can be a mix and match. I have read recently that the EJ18 does not have a cam gear angle sensor for the firing of injectors in 2 batches. Some say this is the reason why they use more fuel. If your wiring loom has a cam sensor, I believe this will fit the EJ18 as there is a mounting point provided.
If you’re going to get a donor vehicle or a half cut it’ll have everything you need. If you’re going to do a [url=http://www.*********performance.com/]c r o s s b r e d brake conversion[/url] a donor vehicle will have the brakes to match the engine conversion.
To get you started, what you need:
-EJ motor, matching pollution gear and exhaust Y pipe
-wiring loom – all wiring under the dashboard and under the bonnet. This will need to be cut down (refer below)
- sensors:
-> Mass Air Flow Metre or AFM – located on the air filter box, you’ll need the top of this box too.
-> Oxygen sensor, found in the exhaust Y pipe
->Cam angle sensor (on motor near the bottom of oil filler pipe)
-> Crank angle sensor (on motor directly above crankshaft, under the alternator)
-> Temp sensor (back of water channel, under intake manifold on driver’s side [Aust])
-> Throttle position sensor (side of throttle body)
-> Knock sensor (on top of block near bell housing on passenger’s side [Aust])
- EJ alternator
- High pressure fuel pump (EFI rated – VL turbo is what everyone goes for, a VN 5 litre V8 one will do the same and probably be a lot cheaper too)
- PS pump – if you have power steering or will be adding it (worthwhile exercise to do)
- EJ flywheel and clutch if using the gearbox or swapping internals
- Radiator modified to take the 40mm radiator hose from the EJ. Best option here is to upgrade the radiator to a twin core custom job that will handle the cooling needed for the EJ. You can fit the liberty radiator in but you’ll need to chop the body cross-member below the L’s radiator and replace it with something that will retain its strength. A few members have done this on the forum (Subafury comes to mind). Here’s my Radiator – custom 3 core for the L, with now modified ports – different angle and 40mm as shown in the pic:
edit: This radiator does not leave much room for thermo fans. Go for a dual core at the most!
Double edit (2019): I’ve been running an N13 pulsar radiator for several years now without issue. You have to roll the top lip of the radiator support panel and I’ve drilled new mounting holes in the lower support bar to fit the radiator as far left as possible, this allows the lower outlet to clear the cam cover. I’m also now running a dual core copper core with plastic end tanks. No way around that. Radiator hoses are adapted with stock liberty upper and lower hoses and a smaller diametre Camry top hose.
Other pieces you’ll need from the local auto store are:
- fuse panel – a 4 fuse panel did the job for me
- electrical clips, joiners and shrink tube
- some sort of protecting cover for the wiring. I used spiral wrap with a layer of electrical tape.
- new water pump and timing (cam) belt. It’s usually best practice to do while the engine is out, especially if you don’t know the history of the motor. Head gaskets can be done too.
For the wiring there’s two ways I’ve seen it done. The one that I have no experience with is wrapping up all the wiring in a protective conduit, connecting everything that needs to be connected (motor only), working out what is power (fused), ignition (fused), fuel pump (fused), oil warning and temp wires. Only the important wires when into the cab, including the ECU wiring and ECU.
The way I have done mine was to cut out anything that was not needed – I started by tracing the wiring back from the engine plugs, taping together the wiring that I needed and cutting out the rest. When I got into the nitty gritty’s (when it became very messy) I traced all wires to the ECU and taped them with a marking tape (green/yellow electrical earth tape). I then refered to Ben’s wiring diagrams (link dead now) to get the wiring cut down completed. You can find the wiring diagrams from numbchux conversions website - a legacy is the same as a liberty.
The wires you need to find to run the EJ wiring:
(Fused):
- main power
- back up power (join to main power)
- ignition
- fuel pump
- starter circuit wire
(non-fused):
- oil warning light (I used the factory L’s wiring)
- temp guage wire (temp guage will sit lower than it did with the EA – again, I used the factory L’s wiring)
- ECU dash light – will most likely need to be added unless its an MPFI touring wagon
- speed sensor wire – this can be left out, I’ve connected mine because I aim to add cruise later on.
Other wires you can find are:
- AC relay wire [edit: used to tell the ECU the AC compressor is on, the ECU will up the idle. Wire this wire the to the AC compressor's clutch wire]
- AC cut wire
- AC fan wire [edit: This wire triggers the thermo fans and can be wired into the factory AC fan trigger wire without harm to the ECU]
- plus a few I can’t remember
Fitting the wiring to your L:
The engine plug wiring was run under the dash along the front of the heater then up over the AC box before passing through the rubber grommet on the left and continuing under the guard (oz passenger’s side). The EJ engine plugs are mounted roughly where the old EA coil was mounted.
Wiring from the rear top of the EJ engine and the AFM wiring passed through the fire wall through an unused hole near the clutch cable’s hole. Using an old clutch cable grommet the wiring was threaded through and the grommet sealed with a few layers of electrical tape. This made it neat and easy to do.
The relays for the ECU and fuel pump have been mounted above the plugs for the dashboard. I took the dash out to fit the wiring in. The ECU is mounted on the steering column above the driver’s feet; I used some thick cable ties. The 4 blade fuse panel is mounted on the column above the ECU – this made for easy tapping of ignition wires for power (always hot), ignition and start.
I used a standard touring wagon wiring loom so the fuel pump wiring was already there – if you have a carbie L you’ll need to run a new wire to the fuel pump. You’ll have to work out something for an ECU dash light (as again mine was there with the touring loom).
The alternator will need to be wired in. On the bottom of the EJ alternator will be a pin-out diagram for the round plug on top. To wire them in using the standard L wiring, use this diagram (thanks to Outback Bloke):
For the fuel return line I used another carbie L’s fuel “in” line as the new return. Others have swapped the fuel return for the evaporation pipe. I did this with my EA MPFI and had surging issues that I thought was a result of this so I upgraded the size of the return line to a standard L’s fuel “in” pipe. Your fuel lines run down the passenger side of the L (and MY). This is the standard return line diameter compared to the L’s standard “in” line:
If you have a carbie L you might want to work out a surge tank to protect the high pressure fuel pump – these pumps use the fuel to keep them cool and lubricated. Running them dry doesn’t do them any favours. You can source an MPFI L fuel tank, these have a larger fuel out pipe to the pump and are apparently designed to keep fuel to the pump. I ran without a surge tank or MPFI fuel tank for a few years when I had the MPFI installed and didn’t have any issues with running dry – just make sure there’s always fuel in the tank...
The L’s engine cross-member needs to have its engine mount holes filed out about 5mm – towards the outside of the subi on each side. You’ll also need to make some wedges to keep the engine mounts on a natural angle to prolong their life. I hammer the top of the engine mounting face flat as there’s a bit of a lip there. On my conversion I used a pair of wedges from the steering columns of a couple of old holdens, a bit of shaving and its all looking good. Square mounts are stronger than the round units from what I’ve been told. Shaved wedge for the engine mount (upside down on engine stand):
If you want to retain the engine stabilizer rod – the one above the gearbox that mounts to the firewall, you’ll have to source an EJ’s stabilizer rod’s bracket from the top of the gearbox, mount this on your gearbox (two or three bolts, pretty simple) then cut and weld your standard stabilizer arm to fit. Mine looked like this – welded one mine, non-welded is a standard lib unit:
Continued...
Post by El_Freddo » Thu Oct 08, 2009 6:19 pm
Use the EJ’s throttle cable, you can use a rats tail file to open up the square hole for the L’s throttle cable so it looks like this (the EJ cable “locks” into place):
Finished product looks like this:
Once you’ve got this sorted its time to fit it all into your L series and fire it up. I found the wiring took the most of my time throughout the conversion. Basic rule is: Get the wiring done correctly first time. – chasing a wiring problem can be a real nightmare and is not something you want to be doing. You may find a member on the forum who would be happy to cut down and tag a loom for you… Expect to see scenes like this (wiring, not stripped doors/interior):
That’s about it – if you have any questions please don’t hesitate to post them, but please be sure to read through the other posts before asking as your question may have already been answered (its called research ;))
PS: For vic members, you’ll want to read up on VSI-8 (1.06 mb) and possibly the VASS engineer’s page for contact details
Post by AlpineRaven » Mon Oct 12, 2009 7:32 pm
Nice simple write up above Bennie!!.
Post by El_Freddo » Tue Oct 13, 2009 10:06 am
Thanks AP, that was the idea!
I forgot to mention that the Power Steering Pump on the EJ will bolt straight into the L series power steering rack - just use the EJ PS lines ;)
drof351
1984 L series Auto
Post by drof351 » Wed Nov 18, 2009 11:12 pm
Hi guys I'm new to this forum and just chasing a few ideas for my car. I have a 1984 L series wagon Auto and want to do a conversion for more power, like everyone else. Can I use one of those adapter plates and keep my auto? If not what's the best way to go? Any help would be greatly appreciated thanks guys
niterida
Post by niterida » Wed Nov 18, 2009 11:20 pm
drof351 wrote:Hi guys I'm new to this forum and just chasing a few ideas for my car. I have a 1984 L series wagon Auto and want to do a conversion for more power, like everyone else. Can I use one of those adapter plates and keep my auto? If not what's the best way to go? Any help would be greatly appreciated thanks guys
Swap your auto for my 5 spd ??
drof351
Post by drof351 » Thu Nov 19, 2009 9:23 am
I wouldn't mind keeping the auto to get it to the ej22 stage then if it kills it think about a better auto or manual conversion. Don't really wanna start changing pedal boxes and hi lo gear lever centre console etc just yet
Post by El_Freddo » Thu Nov 19, 2009 3:54 pm
Dunno about the auto change, but the auto's bellhousing maybe interchangable between the EA and the EJ auto boxes. I'm not sure about the torque converter, or if the bell housing will add any lenth to the gearbox as this would play with your mounts and drive shaft lenght if its significant.
Go the whole hog and do the manual at the same time ;)
drof351
Post by drof351 » Thu Nov 19, 2009 10:33 pm
I'd kinda like to keep it auto. So does anyone know if it can be done with the standard box?
Post by Gannon » Fri Nov 20, 2009 5:09 am
Find an EJ 4EAT box. Im in the process of putting one in my leone.
Because i think you can only interchange the bellhousing between the EA 4eat and the EJ 4eat (which are actually the same box, the only difference being the bellhousing). But i dont think it can be done with the 3at
tex
Post by tex » Wed Aug 04, 2010 5:22 pm
So you use the original EJ flywheel and clutch? Did this work on the EA box I'm confused...
87 targa brumby (Neglected),
+ others.
Post by El_Freddo » Wed Aug 04, 2010 9:51 pm
tex wrote:So you use the original EJ flywheel and clutch? Did this work on the EA box I'm confused...
I have on my setup. I've got an L series gearbox internals in an EJ casing. The only way you can use the EJ flywheel and clutch is if you use the EJ AWD gearbox or L series internals fitted into the EJ gearbox front casings.
Otherwise its an adaptor plate and EA flywheel/clutch setup with the standard EA gearbox.
Clear as mud?
macrules
Post by macrules » Sat Aug 21, 2010 12:31 pm
do you know if there is a place that makes these adapter plates?
Post by El_Freddo » Mon Aug 23, 2010 10:42 am
You can try searching for the BYB product - I know they make them and occasionally you see one pop up on ebay.
SteveRisingSun in adelaide makes them and I think Jeff from Crossbred performance makes them too.
Post by AndrewT » Mon Aug 23, 2010 12:05 pm
Here's a write-up I did on how to make your own adaptor plate.
showpost.php?p=103488&postcount=6
vn-lover
getting a manual ea box to ej motor adaptor plate
Post by vn-lover » Sat Dec 18, 2010 3:50 pm
im looking for info on where to get a ea82 box to ej motor adaptor plate and flywheel, can anyone help ?
Thanks
brumby23
2000 ej 20 into brumby
Post by brumby23 » Sat Mar 19, 2011 2:31 am
hey lads got a forrester that that i want to put most of it into a brumby 88 model just wana know the best way to go about it?
Post by El_Freddo » Sat Mar 19, 2011 11:15 pm
vn-lover wrote:im looking for info on where to get a ea82 box to ej motor adaptor plate and flywheel, can anyone help ?
Thanks
See the two quotes below:
El_Freddo wrote:You can try searching for the BYB product - I know they make them and occasionally you see one pop up on ebay.
AndrewT wrote:Here's a write-up I did on how to make your own adaptor plate.
________
brumby23 wrote:hey lads got a forrester that that i want to put most of it into a brumby 88 model just wana know the best way to go about it?
Do your research. Maybe start a thread where you can ask you're own questions about it. Read other people's build threads. Been done plenty of times before. With a crossbred kit you'll be able to use the brakes as well...
Shouldn't be a hard conversion so long as you go about it in the right ways - wiring is most important. Otherwise if you're good spinning spanners on your subi you should be right if you know what you're in for (research!)
All the best, I'm looking forward to your build thread.
apg39
Post by apg39 » Sun Jun 26, 2011 2:41 pm
Has anyone got a picture or an idea on the sort of exhaust mods needed? I have a couple of stock systems from my old Forester GT & figure I could use them?
Way I see it is use the heavy as fark cast iron stock exhaust headers, get a custom piece made for between where the up pipe starts to where the down pipe meets the mid pipe & the rest should be relatively easy to fabricate.
Andrew
Post by El_Freddo » Sun Jun 26, 2011 10:39 pm
apg39 wrote:Has anyone got a picture or an idea on the sort of exhaust mods needed? I have a couple of stock systems from my old Forester GT & figure I could use them?
You would have to cut this short so that the exhaust goes under the engine crossmember - not over it. If you make it so that it goes over the crossmember you'll have to mod the engine crossmember so that the up pipe has enough room between the driver's side head and the crossmember itself.
So it is possible but will need some imagination. Or you could get a matching Y pipe from an EJ that has the same exhaust port outlets. I believe that there are some models that have siamese exhaust ports like the EA's did. I know my EJ22 has an exhaust port per cylinder.
To get by for a while I had my L series mid section of the exhaust cut down by about an inch or inch and a half then bolted it to the EJ's Y pipe - the joint wasn't a great fit but it sealed enough to get me by for almost a year before I went with a 2 1/4 inch cat back system.
Hope this helps.
