Got my Front struts back, 40mm Bilsteins with rally valving and 300 in/lb progressive springs - looking smick
These are the custom strut top camber plates with a spherical bearing so no rubber mounted bearing.
These are the rear Billy's which I need to get new springs for, I need a higher rated and progressive (not linier) spring. Note the upsidedown top mount bracket.
This is the hydro handbrake cylinder and lines, I am using the original handbrake with the clevis and rod flipped to make it push not pull.
Also I have thrown in a few photos of other bits for interests sake.
Grp A front exhaust pipe - 3"
The modded gearbow xmember
The Plate steel rear diff guard
