Cooling fans staying on.
Any thing and every thing ever asked about how to do an EJ conversion to an L series and MY. Includes Brumby and Coupe.
Phizinza
Post by Phizinza » Thu May 18, 2017 8:35 pm
The Brumby heater tap either directs coolant through the heater core or back to the thermostat housing. It doesn't turn the flow off. Using the heater tap turned "off" is pretty much the same as an EJ heater plumbing with the exception that small amount of coolant isn't cooled through the core.
I still don't have the engine back in due to a little issue with missing detent components on the transfer case. Hopefully this weekend.
Phizinza
Post by Phizinza » Sun Jun 25, 2017 7:12 pm
Just an update. I replaced the thermostat with a 182f which is 83c, similar to the Brumby one. I got a new thermo switch. Now it's working exactly as it should, with the exception that maybe the fans aren't cooling quite as quickly as the large factory one do. I'll find out in the hotter weather if they'll be suitable I suppose.
henpecked
Post by henpecked » Mon Jun 26, 2017 5:59 pm
Glad you got it sorted, when do I get the chauffeured experience ?
Phizinza
Post by Phizinza » Mon Jun 26, 2017 9:31 pm
Going to get it registered in the next couple of weeks I hope
Post by El_Freddo » Mon Jun 26, 2017 10:26 pm
I thought this was already rego'd??
Phizinza
Post by Phizinza » Thu Jun 29, 2017 7:33 pm
Nope. Not yet. Its ready for rego now but I can't afford it just yet.
Post by El_Freddo » Fri Jun 30, 2017 5:15 pm
A painful situation to be in.
I hope this works put for you soon!
Phizinza
Post by Phizinza » Sun Jul 02, 2017 9:48 pm
Gave it a cut and wax today. Changed the oil to some fresh penrite full synth. Scraped overspray off all the glass. Made some small adjustments to the low range lever adaption to solve a reverse/low range clash.
Also swapped the 14"wheels back on the Lib so I can sell them separately.
Post by El_Freddo » Mon Jul 03, 2017 9:26 pm
Look good mate!
You found a set of 14 inch sunnies?
henpecked
Post by henpecked » Mon Jul 03, 2017 10:10 pm
Look closer, i don't think they are sunnies ;)
Post by El_Freddo » Mon Jul 03, 2017 10:19 pm
henpecked wrote:Look closer, i don't think they are sunnies ;)
Well they're not scorpions or desert rats - and they have the factory offset.
Look like a set of 14 inch sunnies to me. I don't know who made them, but that's what I've known them as.
Return to “Fitting EJ motors to MY & L series models”
