Speed sensor pickup - the mount took some time and stuffing around to get it right.  I prefer to mount off the gearbox so the sensor moves with any drivetrain movement eliminating the sensor rubbing on the magnets:
And the all important control pad which is also mounted on a tin plate that's been shaped to fit as best I could behind the little coin tray/storage bucket thing in the dash on the right hand side:
Then I pulled this from the parts bomb the next day:
Cleaned that up, put a new set of boots on and fitted it to Redback.  To get the rack in you need to typically drill out the four spot welds that hold the jacking plate to the engine crossmember:
The brake booster vacuum pick up gets in the way of the PS pump, so I relocated it to the other side of the manifold and extend the hose to fit.  The bung from the other side is moved to plug this hole.  I then had to shave it down to allow the pump to fit without rubbing on the bung or manifold:
And a longer thermostat housing needs to be fitted to clear the rear of the power steering pump:
Here's a dodgy pic of the power steering pump fitted in place - it's hidden pretty well by the air cleaner, the reservoir lid pokes up behind the air cleaner:
This mod transforms the feel of the Brumby - it makes the vehicle feel much lighter than it actually is and now I can throw the vehicle around much easier than previously.  The exact same experience I had after fitting PS to Sunnie the Brumby.
Lastly, I checked out some seats from another vehicle to fit as I was pretty keen to swap the original seats out, even though they're not a bad example of MY seats.  I came up with a bracket that adapts the Honda Integra (early 90's model I think) seats to the MY rails for a direct bolt in application.  Pretty stoked and the seats are awesome, even though the ones I'm using are pretty worn out - I wanted to make sure they would fit and work before I really invested in this mod.  Total cost for these seats to be fitted is $15 on 2m of two inch right angle steel.  They fitted much better than I thought they would.
Pics to come on that mod - I want a better set of seats for the pics!
It's been a busy few days and an amazing change in some vital areas of a vehilce, you wouldn't think this is the same vehicle going by the feel of how it drives.  I also took the time to track down a whistling sound that occurred since putting the bullbar on - turns out it's the mounts for the LED light bar...
Now I can't wait to drive it for some time!!!
