The Brumbyrunner Project
Moderator: brumbyrunner
- brumbyrunner
- Captain Obvious
will there be some sort of bump stop so the tyre wont hit? if not would it be woth adding one?
- brumbyrunner
Sure is Bryan and congratulations to you and Bec.
I'm still using the factory rubber bumpstops which will hit first, and then the shocks have internal hydraulic bumpstops to protect them from bottoming out.
If that isn't enough I can mount some Fox or King hydraulic bumpstops as well but I think that would be overkill.
Settlement Creek Racing
- vincentvega
- Captain Obvious
brumbyrunner wrote:Sure is Bryan and congratulations to you and Bec.
thanks mate will send some pics to bur soon, so have a look see.
also was thinking the same thing dane just posted as well, maybe a rubber flap of some sort?
bryan
- brumbyrunner
We'll have to wait and see how much terrrain gets thrown up into the ute bed. I don't think it'll be as bad as you guys think. I cut out the floor to suit twin shocks before deciding I only needed one. I can always close up the gaps if I have to.
Now that the shock mounts are all done I can build the bumpstop stops. I delibrately ran the trailing arms past the factory bumpstops so that I could build the stops on the side of the arms where I wanted them, and it's easier to cut and adjust them if nessessary.
I'm using the factory rear brake hoses until I get to a brake shop and then I'll run a hard line to the rear of the arm and a much shorter hose. But this will do for now.
I've settled on 23 spline inner and outer DOJs for the back driveshafts. Subaru never made a 23 spline rear driveshart with DOJs on both ends so I'm getting new ones custom made. In the meantime I've mocked up these shafts using 4 front shafts cut and welded together to get mobile.
- brumbyrunner
- Captain Obvious
looking good, keep up the hard work not far to go now!~!
- vincentvega
- brumbyrunner
Yes, it's mobile again. The new rear end is working very well and the new shocks have transformed the ride more than I can describe. We had our first hot test run on Tuesday when a rock punched through one of the rear tyres and then on our second drive the sidewall got ripped out of another rear tyre. I don't know what caused the sudden failure in MTRs after never before having a problem but we switched to the 16" Bridgestone rally tyres and have had no more troubles. Late on Tuesday Wilbur got some footage at a creek crossing and I will try and get that onto utube. I was away for the rest of the week but we had a good long run yesterday afternoon and everything worked well. I think there might be an issue with the speed limiter as it won't rev past 5,500 in top gear (speedo is not working)?
Simply awesome, especially the work done on the rear suspension
I wonder what the engineers at Subaru in the 80's would say if they saw what you have done to their Brumby
Your getting to 5500rpm in top gear? What speed are you doing?brumbyrunner wrote: I think there might be an issue with the speed limiter as it won't rev past 5,500 in top gear
- brumbyrunner
- brumbyrunner
Thanks mate, maybe they'd offer me a job?Suparoo wrote:Simply awesome, especially the work done on the rear suspension
Only 170kms/hour. 2nd video will show it.
- brumbyrunner
- Outback bloke
They are working for me, damn thats quick for a brumby
- brumbyrunner
They work for me when I logged in just now.
Try this link to the menu page.
http://www.youtube.com/thebrumbyrunner
- Outback bloke
