The Brumbyrunner Project
Moderator: brumbyrunner
They're mad. One shot of the D21 Navara looks like the front end is stuffed, but the next shot it's driving along fine. Just amazed at the wheel travel, but it would probably want to be after the $$ that gets spent.
I had a look at most of the shots and the class 4 lads seem to be the ones doing big airs and generally not looking like they have 500km to survive.
- vincentvega
- brumbyrunner
Nothing much has happened here since Finke. Too busy catching up on the work we put off getting ready for the race.
But we finally got the ute home and washed most of the mud off it after sitting in the trailer for a month.
The rear shocks have been removed and sent back to the builder for autopsy. Be interesting to see what failed and if anything can be done about it before Gundy.
I've started mocking up the new rear swingarms and it all looks pretty good. We should be able to mount a 700mm long full swingarm off the rear firewall and still keep the tyre centred in the wheelwell. I'm going to start with a full swingarm and see how it goes anyway. At least we wont have any binding problems like with the factory semi trailing set-up. Just have to build it strong enough so it doesn't tear itself out from under the car. I'm yet to determine just how much wheel travel I can squeeze out of the rear shafts but I think everyone will be surprised.
There's a good article in the latest 4X4 magazine on the Finke race. We get a brief mention and there's a photo of the left rear quarter at scuiteneering but that's it. As Suby owners know, we don't get a lot of attention in "real" 4WD mags.
Settlement Creek Racing
- Outback bloke
- stamp_licker
Was that dirt comp mag?They had alot of buggy stuff in there finke story.
Didn't spot anything gold in the background.
Building a hardcore postie:D
- brumbyrunner
Which edition 4x4 Australia was it in?
- brumbyrunner
Ah.. no wonder because I havent seen it and thought I missed something lol..brumbyrunner wrote:The latest one. September 2008. No.296
It has a couple of Prados on the cover, cutting up the dunes.
- brumbyrunner
- Captain Obvious
i see your putting the jig brumby to good use!! looking good!!
- brumbyrunner
- Outback bloke
- brumbyrunner
One of those options!Outback bloke wrote:Did you end up getting another engine or are we fixing that one?
Here's a link to the flyer of the Gundi race.
Still waiting for entry form & supp regs.
- brumbyrunner
Entry form and supp regs are on offroadracing
Anyone looking for info about the race or accom or camping in Gundy should look here
The rear shocks are back, all freshened up. One of the chrome shafts needed replacing after it got bent when the swingarm bolt broke at the Finke.
My second 5-speed with the Albins gearset, torsen front LSD and new 20kg centre is ready to be picked up and bolted in. I'm looking forward to seeing how much difference the lower ratios make.
- vincentvega
finally some decent info on where to stay out there!! Thanks for the links
hope you can make it stuart. Would be good to catch up.
Looks like Mike Collins (scorpion subaru) will have his buggy ready for the race aswell. Should be good to watch you two out there!
- brumbyrunner
We bolted the rear shocks back in yesterday. Then we adjusted the torsion bars and made a big improvement to the way the inner trailing arm bushes flex relative to the position of the trailing arm. Now they don't run out of their movement range before full bump with the added benefit of another inch and a half of bump travel at ride height. Inital testing shows the rear of the car now has less bodyroll which translates to less power-understeer.
- brumbyrunner
