Off-Road Racing
Moderator: brumbyrunner
- brumbyrunner
I doubt I can make it out there going by this weeks activities. I'll have to drop off some stuff to Outback Bloke (relays, fuel tank stick etc) that got left in my toolbox after Finke and I forgot about while I was getting my gear from Woll.
- brumbyrunner
Thanks Wilbur that would be good.Wilbur wrote:I doubt I can make it out there going by this weeks activities. I'll have to drop off some stuff to Outback Bloke (relays, fuel tank stick etc) that got left in my toolbox after Finke and I forgot about while I was getting my gear from Woll.
Settlement Creek Racing
- brumbyrunner
The competitor list has now been posted on offroadracingdotcom here
Looks like a bumper field of 4WDs.
- Outback bloke
- brumbyrunner
Only!!!!
Better get crackin'!
Fuel tank & spare tyre rack are back in.
Steering rack's back in. Steering column extension was found to have been built wrong so had to make a new one 20mm shorter. The big long power steering hose has been shortened and re-routed.
Drivers side lower control arm has been straightened and repaired and new full size two-piece bushes from Crossbred Performance installed.
New radius rods are built and installed. I decided on an extra 16mm solid bar re-inforcing underneath. The pass side was modified but I built a brand new one for the drivers side (thanks Jeff) because the old one has had a hard life.
Drivers side is all re-assembled with a new 25 spline shaft, ready to bolt the wheel on.
Then I ran out of puff.
- Outback bloke
- brumbyrunner
- Captain Obvious
Not going to make it to this one... good luck!!! cant wait to see some pics!!
- brumbyrunner
Finke Desert Race 2010
So who's going?
I'm pretty sure Dan is doing the service at Finke. Probably take the truck so we have all our gear this year.
The big flash gooseneck with hot and cold running blondes didn't quite make it into the budget this year so we should probably book some cabins in Alice if it's not too late.
- brumbyrunner
- vincentvega
- FROG
So you coming down to sunny Griffith in July Stuart????
- brumbyrunner
- brumbyrunner
- Outback bloke
- brumbyrunner
- FROG
Yeah mate my backyard ..... Got a spare double bedroom if you need it ... The track goes through my mates property I've driven some of it in the ol' liberty .... Prepare for rocky roads
