The Brumbyrunner Project
Moderator: brumbyrunner
what I see in the second pic, (apart from the suspension travel) is how stiff that rollcage has made the Brumby, one stand on one side only. I take it that is no flex at all in the rear?
You have a great job on the whole car and it has been great to see how the car has come from were it was to were it is now, Great job Stuart.
Rik.
Rik.
- brumbyrunner
Thanks Riksta. The whole car is very rigid to stop it from breaking up. The front needs more work but yes, the rear is pretty good.riksta wrote:what I see in the second pic, (apart from the suspension travel) is how stiff that rollcage has made the Brumby, one stand on one side only. I take it that is no flex at all in the rear?
Rik.
I had a few hours to work on the car this arvo but I'm running out of time to get many more improvements done as I'd like before Finke. The new dash and re-wiring job was pretty massive and took up most of our "car time" during the wet season, but it's a good job done and we learnt a lot. If you can remember the spare tyre rack, it was a big solid heavy thing that I built strong to withstand a rear shunt without tearing out of the car. I don't think I've weakened it at all but I've managed to carve a full 1.5kg of steel out of the thing. I'll try to get some pics. Got to love a good quality holesaw (if you don't have a plasma cutter).
More exciting news-: I've been talking to a buggy manufacturer about either modifying the Brumby or starting again with a full tube frame. Either way we'll be widening the track by over a foot each side to get some serious buggy style wheel travel. At the moment we've only got about a 52" track and we need to be aiming for a minimum of 82". I just don't have the time to do it properly anymore, as much as I'd like to, so paying a professional will get it done faster.
Settlement Creek Racing
- vincentvega
WOW! sounds exciting!brumbyrunner wrote: More exciting news-: I've been talking to a buggy manufacturer about either modifying the Brumby or starting again with a full tube frame. Either way we'll be widening the track by over a foot each side to get some serious buggy style wheel travel. At the moment we've only got about a 52" track and we need to be aiming for a minimum of 82". I just don't have the time to do it properly anymore, as much as I'd like to, so paying a professional will get it done faster.
- brumbyrunner
- brumbyrunner
- brumbyrunner
- brumbyrunner
I wanted to stop the gearbox from jumping around as I think the movement might have contributed to our gearbox problems at Gundy. This is the new bush made from an L series trailing arm bush just like the engine mounts.
For the gearbox side I used the pressed factory mount with the rubber cleaned off.
Then I built the bush into a new gearbox cross-member.
- Outback bloke
looking good mate, I hope all your good work gets you to the finish line farster and keeps the car on the track.
Go Hard, Go Subaru, Go the Brumby, Go Brumbyrunner.
Rik.
Rik.
- vincentvega
- Captain Obvious
good luck guys!!! hope all this hard work pays off and you blitz you class!!!!!
Hope it gos well mate, and you make down to Finke and Back in one piece in awesome time!
"Claudia"
"Claudia"
- brumbyrunner
As Brett posted in the Finke thread after this years race, we had a trailing arm failure at the 65km mark but the fatigue cracks might have been there for a while getting gradually worse. I was getting some strange measurements doing the rear wheel alignment before Finke, with the toe changing on the passenger side after a test run but then it settled down and didn't change any further. We checked the trailing arm and the mounts but couldn't find anything wrong. I probably spent more time inspecting the fab work I'd done, rather than expecting factory bits to break, but break they did. The drivers side let go first but the pass. side wouldn't have been far behind it.
These pics shows where the drivers side was repaired so we could drive the car off the track and onto the truck.
You do it hard! nice to see the cross bred kit held up to the endurance testing, what did you end up with in relation to rear suspension?
87 targa brumby (Neglected),
+ others.
+ others.
- brumbyrunner
Crossbred parts are handling the job fine.tex wrote:You do it hard! nice to see the cross bred kit held up to the endurance testing, what did you end up with in relation to rear suspension?
What do you want to know about the rear suspension?
Passenger side trailing arm. You can see where the crack starts, runs around the bearing carrier...
...and on top there are multiple cracks.
- FROG
Any news or future plans Stuart, I've been watchin the Dakar
and been missing my hit on this thread
Cheers Andy
Cheers Andy
