The Brumbyrunner Project
Moderator: brumbyrunner
- vincentvega
- brumbyrunner
- brumbyrunner
That would real nice and neat to have the rollcage colour coded with the car, class is the word that come to mind.
Hope you get all the things done that you need to have done for the next race, good luck and go and kick some Chapmen butt.
It would nice to see a Brumby at the top of the time sheets.
Rik
Rik
- brumbyrunner
Finally got around to rebuilding the rear shock towers this afternoon. I've been putting the job off because I'm planning to get myself a Tig but I'm running out of time so had to mig it all again. Maybe next time?
It's still a time consuming job when you have to notch the pipe by hand and your bender won't work on tight radius bends. Next racecar I build will be in a dedicated shed with motorsport quality bender & notcher. Oh and a guillo and a press brake and and .....
pics to follow
pics to follow
Settlement Creek Racing
- brumbyrunner
- brumbyrunner
- brumbyrunner
- Outback bloke
- brumbyrunner
Well it would depend on the tyre size but with 30"s it gets down to 3" at full bump.Point wrote:looking good! that's alot of travel for those poor CVs. does the diff touch the ground when it's fully compressed?
The only problem with the MTRs is that 3 of them are getting on a bit. We replaced 2 last May so they're only 1 year old but the others must be pushing 4.Outback bloke wrote:I kind of like the gold on the bars.
Are you using the MTR's this year or have you decided on some thing else?
I'd like to run 16" tyres but there's no point buying new rims if we're changing stud pattern.
Looking real smart in the gold Stuart, that gold rollcage looks even better then I thought it would.
I like what you have done with the rear, How did you go with the front X member? and will it be as strong as the rear?
Rik.
Rik.
- brumbyrunner
I built a stronger engine crossmember after Finke last year when the old one cracked up.
I'll eventually replace that with a new fabricated one that'll house a Howe steering rack and new, longer, wider track lower control arms that'll have full movement without binding, like the radius rod setup has now.
- brumbyrunner
- brumbyrunner
That's strange. All I see is a grey square and the code is fine.
To get that much travel without binding you have to ditch the factory camber change rear end. It's entirely possible to build a new camber change design that allows full suspension travel without binding but mine is fixed. It maintains about 3 degrees negative camber throughout the 14" of wheel travel.
