Fat '84 Touring Wagon
- last celtic warrior
OK, news just in... Completely killed the motor this morning, very suddenly. Then proceeded to kill the auto towing the car 100km to home. Not a worry though...
It was very sudden. Car was running perfectly up until this morning, when no sooner had the oil light come on, one of the big end bearings spun and caused the whole motor to collapse in on itself shortly afterwards. Oil level was fine up until this morning's episode, but was suddenly empty. When we put more oil in, it maintained the level perfectly, so I haven't a clue where the other oil went.
Hopefully picking up rebuilt replacement motor tomorrow (still bolted in a car) and connecting that to the spare auto I have already. So not half the drama it could have been. It's entirely possible everything will be fixed/replaced on the very next day after this catastrophic event. Will keep you posted...
Steve.
- INEEDABEER
Break down
I can only tell what i have heard , so dont quote me on it. She broke down in Maryborough. Roscoruby drove up and towed it back. I believe they made into gympie around 5.30 to 6.00 pm . Like i said , that is what i have been told . I have not talked to steve as yet . so i dont know the whole story.INEEDABEER wrote:Who was broken down near Gympie late this afternoon?
rtcb65
Redneck Rick.
Redneck Rick.
motor
Not a rebuild . It came out of a car and was put under the house . I could say i told him so , but i wont. He got it out and test fired it and put it straight in against our better judgement.Matatak wrote:thats annoying...good luck with the replacements.
was it jsut the original motor or had u guys replaced seals and the likes. (guessing it wasnt a rebuilt motor)
was it oil pump failure?
Well we learn as we learn.
rtcb65
Redneck Rick.
Redneck Rick.
- Suby Wan Kenobi
sorry to hear mate. hopefully ur back in action in no time
Hunter S. Thompson
Hunter S. Thompson
Thanks for all the support guys, it's very much appreciated.
I bought another car today with the motor I needed and already have it sitting on the bench with bits swapped over to set it up for my car (and changeover from manual to auto). The guys helped pull that one out and they then pulled my other motor and transaxle out. I knew this car was there for a few weeks now, as that's where my exhaust came from, and at the time I noted that it had fresh heads and the block looked like it had been done too.
Well, after ripping the back housing off the motor I discovered it has new pistons, rings and bottom end appears to be renewed as well. The heads appear to have been new ones, not rebuilt after all. On top of all that, it hadn't even been started up after complete reconditioning. Not bad for the $200 I forked out for the whole car, which I'm handing over to Rick to restore for his other half (the sedan is in surprisingly good condition too). I only bought it for the motor, to drop into mine to get it going after blowing the motor yesterday (big ends spun and tore apart), and have ended up with a brand new motor much sooner than expected, for a pittance.
Anyway, I'm picking up my other auto box from storage tomorrow morning and hopefully will have everything screwed back together ready to drive it home in the arvo. I'm actually really glad the motor spontaneously imploded right now, as it's allowed fantastic things to happen, including scoring a $188 R/C Hummer for $48 at Big W, because it didn't work properly (which turned out to be that the rechargeable battery needed charging up), simply because I had to keep myself occupied while waiting for Ross to drive up from Gympie to where I was stuck in Maryborough.
As for stuffing the auto by towing it 112km at up to 90kph to avoid being wiped out by trucks and cars that couldn't comprehend that we were doing less than the limit, my point of view is that it was an acceptable sacrifice and we'd made that decision before we went and did anything to harm it.
Steve.
She's back
It has been around the 36 hrs now. All seems to be going well. It looks like steve had the luck of the draw. When he brought the leone from the wreckers for a double tun ( $200 ) it looks like it was a total rebuild. Never been fired up since it was rebuilt. Even new pistons so steve reckons . I know the exhaust ports were clean , had the shot peened look. Also looks like the second auto box we had is the better of the two according to steve.
rtcb65
Redneck Rick.
Redneck Rick.
Number 2
And number 2 engine is dead. So back in the shed , well in the yard anyway. This one through a leg out of bed as the saying goes. Rod through the top of the block. We only have one EA81 left so i hope it stays together. This time steve is going to pull it down to make sure it is ok inside . Something he failed to do with the others.
rtcb65
Redneck Rick.
Redneck Rick.
As Someone said awhile ago that the Subie's are bullet proof. Well they may well be but they aren't Steve proof. Ha, ha. He is certainly making a job of this one, but hopefully he will get it right this time. I'm sort of getting sick of seeing it come back all the time not under it's own power. lol:
Lea
Subie Boys's
Roscoruby's
Better Half
Subie Boys's
Roscoruby's
Better Half
Bugger eh?rtcb65 wrote:And number 2 engine is dead. So back in the shed , well in the yard anyway. This one through a leg out of bed as the saying goes. Rod through the top of the block. We only have one EA81 left so i hope it stays together. This time steve is going to pull it down to make sure it is ok inside . Something he failed to do with the others.
Well, third time lucky. I guess you've got some good spare heads now...
new engine
This time it is all out on this engine. Out comes the engineering for this engine. Steve is looking at decompressing the chamber by taking some of the alloy out of the head so he can fit a turbo . A basic system. Just the turbo and the ducting for it and the waste gate into the exhaust. That is the plan so far that i know of. Still running a carby , Pre turbo. I myself will be watching this set up closely , more knowledge for me to learn. As the saying goes : The more you learn, the more you should realize that you didnt know .
rtcb65
Redneck Rick.
Redneck Rick.
Rick's right, I am going all out to make sure this motor is the final one for this car. I was going to build one up over time with a turbo and bigger carby, but that's been brought forward to now, since it appears it the only way I'm going to get a decent motor for my car.
The block I'm using has been sitting around for a while but appears to have less than 5000km on new pistons, cam, bearings, lifters, pushrods etc... I'm putting more fresh bearings in the bottom end and using the brand new heads off my second buggered motor, after increasing the combusion chambers from 45cc to around 52cc. Then mating up an RHB5 turbo with custom manifolds and remote mounted Varijet carby.
The other things I'm doing is cleaning up the motor inside and out, removing mould flashing and blemishes. All the moving internals and their bearing surface edges will be chamfered and linished by hand, making certain every part runs smoothly with all other parts around it.
Here's a couple of pics I took this afternoon. The head is an odd one that is the same casting design as the new heads I have, which I cut into in order to work out material thickness for when I enlarge the chambers.
Steve.
Minor progress, she's starting to come together now that the engineering of the whole thing is done and I'm now left with just painting, assembly and fitting/finishing. The blown motor (the one that has a hole in the top from where the conrod left home) is serving as a buck for measuring and fabricating the plumbing and mountings for everything. Blew the first motor, blew the second one too, so now deliberately blowing the third one before it gets bolted in...
Steve.
