Subie Boys , Lovey80 Resto
thanks barry1956, the boys have always had a passion for the older cars. What they are doing to them is just keeping them alive & well. they love what they do & do what they love.
as a support person for the subie boys, lealaroo, i am so proud of what the guys do, & i know all the positive feedback they get from you guys out there makes them feel great too.
thanks to everyone
lealaroo
thanks to everyone
lealaroo
Ross
1996 Gen 2 liberty Wagon, manual with L series low range Awd and vlsd .
- TOONGA
I wish I was on your side of OZLAND I would be placing orders for all those bits you have made so I could beef up my Brumbylast celtic warrior wrote:Another little update to this "nearly done modifying the crap out of it" project...
Designed and made up the final flanged "subframe bridges" to gusset the front to rear sections of the main subframing today. I'll be making a template tomorrow whilst knocking up the sister to this one for the other side, so it'll be simpler to replicate for other cars in the future (very near future appearantly). As you can see in the pics, it's fabricated out of a basic piece of "C" purlin (1.6mm wall).
Next step (after whipping up the other chassis gusset tomorrow) will probably be fabricating and grafting in one of these to carry the centre bearing on the two piece tailshaft...
IF you were on our side , it would be a good idea . It is only my view, but if ya put a 200hp or bigger engine in a body only designed for about 90, is not to bright. That is why we have put all the extra's into this one. Our own will be getting the same as our cars will get a slight up grade in the engine department.
rtcb65
Redneck Rick.
Redneck Rick.
After putting a helly coil (how ever it spelt) in dales car to hold the exhaust on the motor. Steve started on the center bearing carrier for this one.
rtcb65
Redneck Rick.
Redneck Rick.
Your ones so much better then the one i am half through at the moment, i wish i had the skills to make it look that good.
"Claudia"
"Claudia"
As area's are free from being welded and moded, i hope. The area is wire brushed down and givin a good coat of cold gal.
rtcb65
Redneck Rick.
Redneck Rick.
After making 2 radiator mounts, Steve got back into the cross member. It doesnt look to pretty at the moment, but once the encapsulated nuts are welded in and welded to the brumby tomorrow and givin a coat of cold gal, it should look the part.
rtcb65
Redneck Rick.
Redneck Rick.
- phillatdarwin
Hey Mate,phillatdarwin wrote:i like what u are doing .
can u tell me how u are going to pant over the cold gall ?
That is a good question. I would like to keep the cold gal to help the rust resistance . Only prob with that is, not sure if the paint and paint prep will go over it. In theory , the cold gal is self etching , so it bonds to the metal. If we etch prime that , etch should bond to the cold gal. Then undercoat and paint. In theory. But how many things work in theory and don't work reality. There's a few , and some how i think this might be one. If it doesn't work, it is a simple case of , take all the cold gal off and start with the etch and then under coat and so on.
rtcb65
Redneck Rick.
Redneck Rick.
- last celtic warrior
Hay Rick, if you google "cold galvanizing paint" you should be able to find all you nead to know about what types of paint you can paint over it.
from what I know you can allmost put any kind of paint over it, but it depends on what type of cold gall you have used.
Have a read yourself and see what you think.
The car is coming on nice, keep up the good work Guys.
Rik.
Rik.
- phillatdarwin
A few more pics of the finished floor structure (remember it has those full width beams on the inside too).
I gave the underbody a good look over after welding the member in and zipping a few welds around the seat belt mounting plate, and I felt pretty good about how everything worked together. I seriously want a drive of this car once it's on its wheels again, to see how different it feels over a standard Brumby (should feel more like a Bugatti Veyron chassis...).
Steve.
More area finished with the welding so it has been re wire brushed and givin a coat of cold gal.
rtcb65
Redneck Rick.
Redneck Rick.
Steve has been down for the last couple of days and has been working on the wheel well. It has been moved up a little. More has been done since these pics were taken, but i dont have a update pic yet.
rtcb65
Redneck Rick.
Redneck Rick.
Hey Guys, The Ute looking great, i wish i could get my brace looking as good as yours does... I just finished my brace for the 5 speed on mine although i didn't do the top piece brace and feels really good and solid. Also just put a front strut brace from Jeff (CrossBred) and it corners and feels way better i should have done it years ago. Also the ratio's really suit the EA81 down to a tee.... It is really worth the effort..
"Claudia"
"Claudia"
Hey Matt, Well done on the making and fitting the cross member. I agree, with it being a great idea. Ross likes the the 5 speed since he put it in.Matt wrote:Hey Guys, The Ute looking great, i wish i could get my brace looking as good as yours does... I just finished my brace for the 5 speed on mine although i didn't do the top piece brace and feels really good and solid. Also just put a front strut brace from Jeff (CrossBred) and it corners and feels way better i should have done it years ago. Also the ratio's really suit the EA81 down to a tee.... It is really worth the effort..
rtcb65
Redneck Rick.
Redneck Rick.
A more up to date pic . The well should be finished tomorrow , then not much metal work to go after that. A couple of encapsulated nuts to be replaced and any final adjustments once start test fitting.
rtcb65
Redneck Rick.
Redneck Rick.
