1986 Subaru Leone RX TURBO STi
- nico leone
Re: 1986 Subaru Leone RX TURBO STi
time to assemble the wagon engine, the the spare motor for the sedan or the wagon lol*
what its going to look like*
can't have a new motor with out a good transmission, so I took apart my spare STi 6mt to change some synchros so its smooth like butter.
- nico leone
all primed up and ready for the single stage white paint job to match my sedan
here is the pistons I made and got wrinkle red powder coated my valve covers
so after trying to rebuild my steering rack it seems that seals are impossible to source so !
The old school Subaru guys are going to find this one interesting !
1986-93 GL-10 TURBO engine Crossmember
1991-04 New age Subaru Steering rack
what we have here is a option that I can take advantage of
18:0 GL-10 steering ratio
15:1 STI 2004 steering ratio ( my new rack is on the way )
So neat mate!
Can you have Ruby Scoo and Redback Brumby sprayed after yours for me?? :P
Keep up the good work. You’ll have a fleet of beasts!
- nico leone
lol if I won the lottery id have every Subaru model done up
Single Stage White 80's paint for my 88 GL-10 TURBO
- nico leone
today was exciting !. A 2004 Subaru STi Steering rack showed up, its time to install this into my old school 80s subaru engine cross member
so here is the issue, the lines need to be a little bit longer and then you move the bracket over to where the fancy factory sticker is.
take the bracket off and move the lines out the way, so there we have it, it fits right in the spot.
also we have to make it look original that's how I roll, sometimes lol !!
with the same bracket I cut out the U shape a little more, this way I can bolt it up like stock. then I flipped the bracket around so I can put the bolt on the top, this makes it easier to install.
you have to bend the lines into place for a little length which you can do by hand.
Ps: you have to enlarge the holes on the crossmember beforehand, and then cut the pocket out on the opposing side so the lines can stick out
what I gained from doing this
18:0 GL-10 Steering ratio to a impressive 15:1 04 STi Ratio, that's 4 ratios quicker. id say that's more impressive then everyone only upgrading from 15:0 to 13:0 (3 ratios )
Looks good Nico!
What’s the difference in the rack end pivot point? Will this have any negative effect on steering and suspension roll points - or even push the rack ends out too far for the tie rod ends to be where they need to be?
I don’t necessarily know what I’m talking about from a knowledgeable point of view about bump steer etc, more curious of any changes in width of these components and the effects on steering and suspension in an L series setup.
- nico leone
my room of mess and my SS made pistons along with pins so there is never rust
- nico leone
no more need for the hoist so its time to work outside and finish this wagon
test fit
test fit
- nico leone
finally found the 5mt trim plastic for the Leone and bonus button that will go with it
also found in Japan new door tops
picked up a factory set of JDM Leone RX floor mats in grey to match my car super rare
got my interior in
got my interior in
- nico leone
Goodridge brake lines made up in all SS including the bolts
picked up a set of VOLK RAYS 16x8 ET42 5x100 Wheels so I can put the power down the some bigger rubber 225/45R16
had them sandblasted and they will be white
- nico leone
found a original front lip in Japan so it looks like the sedan
was time to take care of the intercooler and like the sedan I got a nice BELL intercooler made up
the bumper plastic isn't bolted up that's why it sits like that or else it will sit straight, I have a brand new skin coming in
- nico leone
got the turbo sorted out so the wastegate won't hit the wall
SS feed lines and fittings so never rust
got my PROvent 200 all set up so it can catch all the oil
also add the radiator cap on the radiator like the factory had it so its clean and works flawlessly
2 x 12" opal fans made in Italy, the driver side has a bigger HD motor then the slim passenger side
- nico leone
Setrab oil cooler fits so nice ill have to convert the sedan to this model soon
- nico leone
these Subarus don't really have a proper toe adjustment so I came up with a heim joint with threads so I can adjust the Alignment much easier, and its all made out of SS so it will never rust
original subaru leone
Version 1 : hard to adjust live on the alignment rack.
Ver II perfection !
made this long time ago for the bushings in the arms now the wagon will have all pillow ball heim joint ride like the sedan
Ver II perfection !
- nico leone
ordered up the aluminum tubes for the intercooler and radiator pipes
first step was get the radiator pipes made up, lower & up pipes for both sedan and wagon
more alignment goodnesses stuff in SS, radial rod fully adjustable for caster & centering the hub under the body of the car.
Stunning work as usual Nico! Wish I had the funds to do a build to this level of quality on Ruby Scoo!!
That rear toe adjustment looks neat. I’ll be keen to see how this device effects your camber as those three bolts are key to this setting. It’s not very well documented as to how to adjust it. I’ve seen an official note on this adjustment once on the USMB but haven’t seen it since. Wish I took the time to save it!
Keep up the good work!
