we start of with a stock 1986 Subaru GL-10 FWD TURBO orig 28,000kms 17398.miles. weight is 910kg 2002lb car !!
the parts car for awd and 5x100 86 xt6
so what we have hear is to add the 4WD system into one of these cars, those are 20MM sway bars, above the sway bars is what holds the diff, about that is a mix and match of old and new to hold the STi 6mt, above that is a updated version of control arms to hold the 5x100 knuckle.
rear axle XT6 for the R180 3.900, there is a trick to these where i mix the outer with the new style inners to run a R180. or i could just stay light weight and put a R160 in it.
cusco motor tranny mnt
ARP head studs, Cam & Crank sensor new oem
