My plans are to put complete Liberty/Impreza running gear underneath it - crossmembers, shocks, brake, steering, diff, gearbox etc etc.
Hmmm no mention of a motor - that is because I am going to put a Rotary in it
Cool - I've only ever seen one Rotary mated to Subie AWD and that was a Japanese WRX - could only find photos of the completed car and no info or pics about the build.spike wrote:been done.............
only in a leone
now THAT would be awesomeTOONGA wrote:8 cylinder rotary aircraft engine?
haha - 12a, 13b or 20b i'm not fussed whichTOONGA wrote:A 13B or an 8 cylinder rotary aircraft engine?
make sure there are lots of pictures and writing
Yeah both motor have a basically central crank, rather than one towards the bottom on 'normal' upright motors so I think it is an ideal swap - very surprised that it doesn't seem to be more popular, especially considering the rotarys lack of torque could be beneficial to the weak old WRX gearbox.subybrumby wrote: Of course its very doable and I wish you every success with it.
rotarys are apparently the best to run with hydrogen, somthing about compression and the heat stored in the combustion chambers not really sure just know you can run rotarys with a compressed hydrogen hose over the inlet (without the fuel hooked up)1111giles wrote: But this is the bit thats interesting - its been viewed as a Hydrogen burning engine - and by its design gives a full 4 stroke power cycle every 360 degrees of shaft rotation ! - now that would be an interesting engine swap !
Oil consumption ? Nothing like the smell of 2 stroke. I am a mad 2 stroke and rotary fan. Its not going to be an every day car so fuel and oil consumption is not an issue.1111giles wrote:The mazda rotary is well known for its thirst for oil - does this concern you?
The power/torque curve of these type of engines is about as far away from that of a Boxer 4 as you could possibly get, the result is that you will have a vehicle which maybe good for dragging but not so for its original intended. I take it that you wont be concerned by this change in status?
What does one of these 'lumps' weigh ? if there is a huge difference will you be looking at the front weighting of your finished BrumbyRocket?:mrgreen:
BTW - I do have some insight into the mysterious world of 'Rotary' engines, in that my father has designed a totally new rotary engine dubbed 'RICE' which stands for R otary I nduction & C ompression E ngine.
His design is at the development stage right now and is currently the subject of gas flow analysis research work at Cranfield University (Engine development centre). IF this passes out AOK then we are up and running with it !
