Doug's EA81 Rebuild stuff.
Hmm, when I click the link its in english??
Ive seen those heads before. Donno how well they would work in a car though. They look about twice as big as normal ea81 intake ports. They would probably scream like crazy but have little torque. If I wanted that Id use an ea82
. Would probably need a supercharger to get the full benifit of that sort of head in a car. By then though, If your chasing power there are better alternatives.
I think for what it is, give the ea81 a port matched intake manifold, clean up the casting impurities in the ports, good valve job, good flowing ehaust system, upped CR and EFI with electronic mapped ignition curve ~10-15% would be in the scope. More If your revved it harder but I believe the EA81 is all about torque. If you could get the intake to flow well, then there would be dramatic improvements from forced induction. As the heads are at the moment......Well Its like bad food. Your can cover it in sauce, but at the end of the day, your still eating bad food covered in sauce
Doug
Doug
have a look at the link and it looks to be an en translation of the Italian original with a 'net translation flavour to it - maning a human likely to do a better job of it.
You could do all that and have it use more fuel too - then get upset with that aspect - tweety is one example.
Spoke to a fella who claimed he near matched a Falcon turbo with his NA Falcon, copped an increment with fuel use to its power increase and ended up trading down to a 4 cyl girls car - with no mods.
Contacted SUB4 years ago to get an idea of cost of their heads and roller rockers - was beyond my budget by far. They ran their parts in their dark blue Brumby.
Well what did he really expect? more power but no more fuel consumption. Power comes from burning fuel, getting more power comes from getting more fuel into the cylinder. Turbo Cars have manageable fuel consumption because they only use more fuel under boost, when its needed. A N/A car that can match a Turbo car for WOT HP, during coasting and crusing its still running a very high Volumetric efficency, where a turbo isnt. Thats why turbos are the bomsteptoe wrote:have a look at the link and it looks to be an en translation of the Italian original with a 'net translation flavour to it - maning a human likely to do a better job of it.
Doug
Got some work done today, quick clip for you that are interest,
http://www.youtube.com/watch?v=wPoPslbx ... tube_gdata
Mechine is a shaper, very old. Chugs along and gives arguably the best finish you can get. Better then a grindstone, better then a mill cutter. silky smooth.
Ended up taking around 40thou off the heads, should ramp up the CR a bit for a little bit better torque.
Whole process took around 5 1/2 hours to do both heads.
Doug
Doug
Being EFI Turbo they didn't really require the opposite valve (twin port) arrangement like the twin carby model. They only ran 5-6 psi, so it didn't require full flow setup but if you're staying NA then I'd go the matched porting and exhaust polishing.Subydoug wrote:Oh really??? They didnt use the better heads??? Thats crazy! What were they thinking?? That'd need a good custom port job to be any good I think.
LOL.. what hatch?? I'm thinking you make the Touring Wagon a turbo and supercharge the XTSubydoug wrote:Tell you what, Il finish this motor off, Then When I pull the old motor, I can stick those on it with a nice sized turbo, and Paul can stick it in his Hatch. (hint Hint Paul
I could certainly feel the 4lbs boost from the SC. Nice torque upgrade. I would imagine It had a different cam as well? The MPFI itself would have given great throttle responce.RSR 555 wrote:Being EFI Turbo they didn't really require the opposite valve (twin port) arrangement like the twin carby model. They only ran 5-6 psi, so it didn't require full flow setup but if you're staying NA then I'd go the matched porting and exhaust polishing.
Il give you a hint, Its Blue and its awesome
As for the XT, anyone care to swap their ej22 for a lovely piece of subaru ea82 history
Doug
I think for what they are, and for the specific jobs they are made to do, they do a flawless job. I wouldnt think twice about doing cylinder heads in it. The finish is that good I wont need to touch it before assembly.steptoe wrote:I guess someone had to end up with shapers out of closed down schoolsline up behind the industrial arts teachers ...... Some brave camera work there Doug
Yeah you do have to be exceptionally carefull around the old shaper. The urge to feel the cut finish can become overwhelming and before you know it, Chomp. Bye bye finger
Doug
Hey Fella's
Cleaned down a bench. Pulled the rest of the gudgeon pins, popped the bolts out and yanked the crank case apart
Just finished degreasing the case halves. Will sandblast them tomorrow. Measured the bores, about half a thou out of round and about 1 thou within service limit
. No rebore needed. Just a light hone and some new pistons and it will be on its way for another 200k. Speaking of which, Paul any ideas on the km's of this engine? Bearings all look great (doesnt mean much, I dont have the tools to measure) but are getting replaced.
So now some tidy up, sandblast and paint job, wait for some bearings to rock up in the post, slap the halves back together, drop in some funky piston thingys, Bolt on some miscellaneous parts that will remain undisclosed for now and unleash terror on the road
The waiting begins.......
Doug
Doug
- Silverbullet
Oh wow a shaper! Only seen those in books and tales from the old tool makers at work. A pretty decent size, you do a lot of work on it? 5 hours....now I see why they moved to bridgeport style milling machines
Its actually my dads. It has an 18" stroke. Mainly used now for the odd key slot in big gears. Its had a pretty hard life. Also has a mill and lathe. Chose to use the shaper because of the finish and ease of tooling and setup. If I had to do another 2 heads now it would probably only take me 3 hours. Took it pretty easy on the first head. Great tool to just set up and carry on doing something else, Just lean a crowbar up against the travel so it knocks it over when its done
Doug
Doug
Arh ok no worries.
Latest update on the motor. All dissasembled, cleaned and blasted.
Blasted the rocker covers and sump cover too for a fresh lick of paint. Sump has a lot of ground in grime so Il attack it with sand paper beforehand. What color should I go?
Cylinder head, rocker side.
Cylinder head, combustion side,
Bell housing, still need to peel off that sealant.
The block, rear view.
The block, sump view.
The block, Inside.
I didnt sand blast any mating surfaces. I also didnt sand blast inside the motor. To remove the tarnish brown I use some Degreaser. Degreaser was alkaline based. 20g/L sodium hydroxide and 50g/L Alkaline salt UN 1760. Peels it off with a squirt and rinse, no scrubbing. Be warned though, that degreaser is just as bad for you as acid and will burn if left on your skin (corrosive Eight) so be careful if you use it.
Doug
The block, Inside.
Doug
- Silverbullet
